Black Box and Rotary Axis
Discussion in 'General Talk' started by Jim Robinson, Dec 2, 2019.
  1. Jim Robinson
    I have an old ender 3 that I have been using for small laser projects and recently need to add a rotary axis. Marlin does't seem to want to run a rotary axis with out having to do a bunch of firmware changes (and even then it doesn't play well.) I purchased a black box earlier this year for a build I haven't started yet. So my question is to set up the 4th axis as A axis do I just leave the slave jumpers off? All I can find in the documentation is how to set the forth axis as a slave to X, Y or Z, is it possible to run it as a true forth axis (a)? I think I may just run the black box to run my ender 3 hardware with a rotary axis util I get around to building my other frame. Any insight on this would be awesome!
    Ryan Lock likes this.
  2. Giarc
    I do not believe GRBL is capable of a 4th separate axis, just a slave.
    Correct. BlackBox's 4th (Y2) driver is just a slave jumpered to X Y or Z. See docs.openbuilds.com > Slave axis Jumper
  4. Jim Robinson
    Ok will it support a rotational axis as one of the three?
  6. Ryan Lock
    Ryan Lock Veteran
    As above have said GRBL is limited to 3 axis. If you want to control more than 3 axis the Duet controller which is used in 3D Printing and CNC'ing can control more than 3 axis and is fairly simple to setup: Gcode
  7. Sk8nmike
    Sk8nmike New
    Ok, new to building a CNC, been using them for many years. Let's see if I have this right. 3 Axis is a limitation of the Control software, not the BlackBox? if so is there control software to use with the Blackbox that will allow 4 Axis operations?
    No, Grbl is limited to 3 Axes (BlackBox runs Grbl Firmware - see github.com/gnea/grbl).
    However, as noted before, that's not a big limitation. In a typical CNC you are either busy doing 2.5/3D work (Plug Y axis motor into Y port) or doing Rotary (Lock gantry above the rotary axis, then plug the rotary's motor into the Y motor port. Then just use Gcode Wrapping to run the Rotary as a Y axis. Simple, cheap, easy
  9. Don O
    Don O New
    Hi Peter, I have read a lot of responses concerning a rotary 4th axis with GRBL on the Blackbox. I currently have the Blackbox and use V-Carve pro as my CAD program. V-Carve can design a rotary item but will it run on the Blackbox on the Y2 Axis?
    Yes, use the Wrapping function in Vectric to wrap it about the Y axis
  11. Don O
    Don O New
    Thanks Peter, I’ll give the a try.
    See posts #26 and #27 in LEAD Lathe too
  13. BlackEdition
    Is there a way of achieving this axis wrapping in fusion 360?
