Pen Plotter
Discussion in 'CNC Mills/Routers' started by MAFFPL, Jun 4, 2022.
  1. MAFFPL
    MAFFPL New
    Good day. In the cam software I found the option: Pen Plotter. Can someone explain to me the principle of operation? Do I need a special adapter for my LEAD 1515?
    Its for use with Servo based pen lifts. docs:blackbox:connect-rc-servo [OpenBuilds Documentation]
    No official adapters around but plenty of DIY ones on the forum and 3D printable ones too. Just a slide that drops pen onto paper under gravity, and lifts it up between plots using a cheap RC servo
  3. MAFFPL
    MAFFPL New
    Thank you, do you have any proven solution, could you recommend something?
  4. Giarc
    Is your goal to produce art work, or just draw simple line drawings. I some times draw my parts and cut them out on paper so if I have small work stock I can center it and be sure it fits. I use a simple holder that has a sharpie marker in it. I then put the holder into the router collect. I use a simple engrave tool path with a 0.1 mm depth of cut. My holder is a 3d printed spring loaded holder that uses a 1/4 20 bolt which is placed in the collect. It is simple without any major modifications.
    Mine is similar to this one. CNC pen / sharpie holder for plotter by Oscarko
    An example of me doing this is in the video in this project if it helps:
    Magnetic Bait Cutting Board For Hobie Kayak 8" Hatch
