Leveling Spoil board
Discussion in 'CNC Mills/Routers' started by marlin adams, Jun 22, 2022.
  1. marlin adams
    I bought a OX cnc kit total size 750mmx750mm with a working area 570x525mm. So finally after a year I got it together and using electronics from Openbuilds. I am ready to level the spoil board and wondering what size bit would be optimal?
  2. Alex Chambers
    That depends to some extent on your router/spindle as well as the rigidity of your machine (which depends on how well you built it).
    I use a 20 mm router bit (because they are readily available and cheap - but then so am I) 20~25 mm is a good guess.
    marlin adams likes this.
  3. marlin adams
    It is very rigid and I am using a makita RT0701 and thank you for the reply
