10v analog signal not linear
Discussion in 'CNC Mills/Routers' started by Artver, Jul 31, 2022.
  1. Artver
    Artver New
    Dear all,
    I am using the Blackbox to control a AMB (Kress) 1400 FME-P DI.
    It is wired up to use the 10v analog signal to control spindle speed.
    It is wired like shown here (this should ensure my ground is proper).
    It works, sort of, and I can have the spindle run at different speeds. However, I cannot trust the voltage/rpm.
    Given it is 0-10v I would expect 100% speed to give 10v, 50% to give 5v, 25% to 2.5v, 10% to 1v etc.
    I can adjust the max output (10v/100%) through the 10v trimmer on the Blackbox, but not the other values. I am getting these readouts at the spindle:
    100% speed - 10.5v
    50% speed - 4.45v
    25% speed - 1.42v
    10% speed - 0.139v
    According to the documentation of the AMD 1400 FME-P DI, the spindle speed is 0 from 0-1v, 3500rpm (minimum) at 1v, 25000rpm at 9-10v. It is linear from 1-9v as documented here.
    I need input/suggestions on how to calibrate/adjust the Blackbox 10v control signal to actually be linear and reliable.
    I would like to be able to enter eg. 12000rpm in my gcode and actually get 12000rpm.
    Martin
    The linearity is not adjustable, but should be fairly accurate - at least good enough for the use case. You won't notice the difference between commanded and actual RPMs on a Kress spindle (it will even vary during the cut as the load changes through the cuts)
  3. Artver
    Artver New
    Hi Peter.
    Thank you for your quick reply.
    I don't think the voltages I am getting are fairly accurate. Do you believe they are within acceptable limits?
    10% giving 0.139v is way off I think, as I would expect it to be 10v.
    Contact support openbuilds.com > new ticket and we can help you check
