Error 9 g code locked out
Discussion in 'OpenBuilds Forum Help' started by CKerv, Aug 7, 2022.
  1. CKerv
    CKerv New
    Anybody know what may have caused this or how to prevent it in the future. It happened a few times, in the middle of running and operation, without any obvious reason.
    error 9 - G code locked out during alarm or job state. [X63.93 57] Screenshot 2022-08-07 001119.png
  2. Alex Chambers
    Do you have a vfd/spindle? If so where have you put the cables?
    Vfd's & spindles create tons of emi (interference).
    Keep the vfd away from the controller and the cabling between the vfd and spindle away from all other cables - especially don't put it in the drag chain parallel to the limit switch wiring.
    Oh, and shielded cables don't always solve the problem - physical distance is best.
