Dash X Direct, Cross-Beam 3d Printer
Discussion in '3D printers' started by Neil Rosenberg, Mar 29, 2022.
  1. Neil Rosenberg
    Neil Rosenberg Journeyman
    Neil Rosenberg published a new build:
  2. larosta
    larosta New
    Neil, like the upgrade and will be updating my Dash X as soon as I can find the extruder in stock.
    Some questions:
    1) Do you have a suggestion for an alternative build plate as the original Anycubic Ultrabase print surface, 310x310mm appears to be out of stock at my usual suppliers?
    2) Can you suggest a source for the “yellow rod” that you used for the cable gantry?
    3) Will you be posting the SolidWorks files soon?
    thanks,
    larosta
  3. Neil Rosenberg
    Hello and thanks for the inquiry.
    1. I am switching over to PEI coated flexible steel magnetic print surfaces. All of my Ultrabase beds have started to fail. There are many such beds on Amazon, I prefer the ones with smooth PEI (not textured).
    2. The yellow rod is actually fiberglass "Fish Tape", such as https://www.amazon.com/Fiberglass-Running-Coaxial-Electrical-Connectable/dp/B085T61P9J Cut to length, there's enough there for many printers.
    3. I've been trying to post the Solidworks Pack-and-Go, will give it another attempt now. The web site fought me earlier.
    Regards
    Neil
    P.S. I got my extruder from Filastruder. Good price, looks like it's in stock now: E3D Hemera
    #3 Neil Rosenberg, Mar 29, 2022
  4. Neil Rosenberg
    #4 Neil Rosenberg, Mar 29, 2022
  5. larosta
    larosta New
    I downloaded the SolidWorks file from your Google Drive > uncompressed it >
    When I try to open it with my version of SolidWorks 2021 I get a message that the file cannot be opened because it uses features is for a "future edition".
  6. larosta
    larosta New
    The "Dash X Direct.STEP" file opened in SolidWorks but I could not extract or open the individual part files.
    Could you please post the .stl files for the "Hemera Mount" and the "5015_Hemera_Shroud_v0.3" as I believe that these are the only parts I need to make for the upgrade.
    - larosta
  7. Neil Rosenberg
    No problem. I just posted it in the "Files" area, will be live as soon as they approve it.
    BTW, you can get Solidworks for Makers for $100/yr. It's the full version, the only limit is that it's strictly for non-commercial application.
    Not sure what the problem is with the STEP file. It imports fine with my Solidworks and I can open individual parts and export to STL.
    Neil
    #7 Neil Rosenberg, Mar 30, 2022
  8. JustinTime
    I opened the STEP file in Fusion360 and have no problems at all with it.
  9. larosta
    larosta New
    I have the 2021-2022 Student Edition of Solidworks and am not sure why the files won’t open. That said the .3mf files you posted work great. Upgrade parts made and the extruded I on the way. Looking forward to upgrading an already great machine. Keep up the good work.
  10. Neil Rosenberg
    Thanks and good luck with the build. Let me know how it goes, please.
  11. Neil Rosenberg
    Unfortunately the 3DExperience version (which I was using for a while) of Solidworks creates files that are not compatible with the Student edition. I had the same problem when transitioning back to the Student version (teaching again).
    Since I always have trouble uploading large files to this site, here is a link to a pack-and-go that can be read into Solidworks for Students, 2022:
    https://drive.google.com/file/d/1fmtZEFOmENMZzi4o7gWtEmgKcwDhLg-o/view?usp=sharing
    Let me know how it goes, please. Enjoy!
    #11 Neil Rosenberg, Aug 27, 2022
  12. mikkythomeon
    Hi Neil and others,
    In 2019 I bought a Tevo Tarantula 3D printer. After about 2KG of many failed prints, and a wife who complained that the printer got more attention than she did, I decided that I needed to fundamentally change the design of the printer I was working with. It was wobbly, and regardless of how many 3D printed addons I created, it never achieved the "Set and forget" level of performance that I had first envisioned.
    I can perfectly relate to Neil's experiences as mentioned and I could also write a book's worth of all my failed designs whilst not fully understanding why things are designed they way they are.
    There are not many DIY entry level printers that are designed and built on solid engineering principles, and when I saw Neil's design, I was hooked. Considering that I have a penchant for perfectionism and have little cash to throw around, I introduced a few more physical and cost constraints. But considering family and work requirements, there has been little time left to continue building this impressive machine.
    Before I continue further, I need to make serious mention that the time and effort to create a 3D printer like this can be longer than the time to master certain basic workshop skills. If you are not very focused on your objective, you can go down a long and winding path, trying to design and improve all sorts of machines. Along the way I bought an entry-level drill press with a collet that introduced wobble on the chuck, and, not being satisfied with the accuracy I could get out of it, I went further and bought a slide vice, which is a great tool, but only two weeks ago did I find a solution to stop the drill chuck from wobbling. Since then, I have so much more capability. Using the drill press to tap holes has also been a game changer. My slide vice has a thread pitch of 3mm, so I have recently realized that basic drilling can be done by counting the revs of the handle on the slide vice. To 3D print an object or not should be a consideration. I have designed about 5 or so designs that used elaborately 3D printed parts which in fact can actually be achieved using flat metal plates, which are infinitely more durable. What it cost me to print these parts likely far outweighs the cost of buying the stock parts, or being able to make basic parts from aluminium. If you think of it, this is what OpenBuilds is trying to achieve - standardization, which in turn reduces costs and allows people to focus on the outcome of creating things that other people can use.
    I have posted a pic of my machine below (in the background). The machine is built by recycling 50% of the Tevo Tarantula's parts, and using as few parts as possible. This has turned out to be a 3d puzzle of note. I cannot tell how many times I have shifted things around on the printer to find a way to maximize the build volume, make everything fit, whilst keeping the costs low, and trying to make it as ergonomic as possible. The printer frame is 460 x 440 mm and I get an xy movement of 310 x 360mm in the XY plane. Not too worried about the height at this stage. There is still a bit of ground to cover, but in the coming months, if the tide turns, I will complete it and post the finished design.
    We all need a bit of recognition from time to time, so thanks to Neil for the inspiration.
    I have just recently learnt about a belt printer, and it seems that Creality has taken over the market for 3d printers in general, but guess a belt printer will be my next big project that will keep me engaged for the next few years :)
    Cheers,
    Mike
  13. JustinTime
    It may not appear to you that it's true but you'll achieve much better results if you put the printer on a solid surface and not on two surfaces one on each end.
  14. mikkythomeon
    Thanks Justin, it actually has screw mounts that I will use to bed it down properly when I get it finished :)
  15. Kermit
    Kermit New
    What slicer settings should I use to print out the parts? (ie layer density etc)
  16. Evan870314
    I converted the Dash X Direct.STEP file into a FreeCAD file, I will attach the file.
    The only issue I have seen so far from converting the model from a .step file into the FreeCAD format is the orientation is off. When viewing the model in FreeCAD 0.21.2 and you choose top view, the front view of the model is given.
  17. dprice
    dprice New
    The E3D Hemera is getting phased out. What modes are required to use the lighter/smaller Hemera XS? Any thoughts on the BIQU H2 V2S Revo as a substitute?
    Thanks in advance!
  18. Neil Rosenberg
    Hi there. I haven't worked on the Dash printer for quite some time. As long as you are comfortable with CAD you can adapt almost any hot end/extruder you like. Of course you'll need to adjust your Z-Zero and any relevant motion settings in the firmware (i.e. max acceleration). I don't have first hand experience with either of the units you mention, sorry. I've switched over to be more of an "appliance user" lately, with multiple Bambu X1C printers.
