Trouble with the Open Builds Control
Discussion in 'CNC Mills/Routers' started by Joseph Casalino, Sep 3, 2022.
  1. Joseph Casalino
    I was setting up the X-axis calibration and was adding the travel difference between the 100mm and the actual travel distance, when for some reason the jog feed speed went very slow. I am using the C-Beam XL, as the machine to control. It says to 'save when done'. I cannot see where that check box is, on that page. On the control page, I tried all the speed 'slides' and nothing seems to work. What made the speed drop and how do I adjust it? Since, I am doing a very simple move with the table, I was wondering about writing my own G-Code, I do that on the CNC Mill now. Is there any info about writing a proper program?
    Thanks,
    Joe
  2. sharmstr
    Perhaps something happened to the settings when you saved the calibration. Maybe you fat fingered the calibration value. Also have a look at max speed settings in the grbl tab. If nothing looks off, go ahead and post all the settings here so we can take a look.
    grbl uses a subset of command of linuxcnc. You can see a list of supported commands here: Grbl v1.1 Commands ยท gnea/grbl Wiki
