Custom 4x4 CNC
Discussion in 'CNC Mills/Routers' started by Sray69, Nov 3, 2022.
  1. Sray69
    Sray69 New
    Sray69 published a new build:
  2. JustinTime
    Seeing the sturdy machine you've built it funny to think that you even considered a MPCNC. It's literally day and night difference. My self designed and built machine is by far not so sturdy but I only cut wood (so far).
    Only thing I would have done different than what you did, and what I did on mine, is using NEMA 34 steppers. They are way stronger for their size and cost about the same as the high torque NEMA 23.
    Great build, my friend! :thumbsup:
  3. GKTRK
    GKTRK New
    Wow that is AMAZING!
  4. Banjopete
    Banjopete Well-Known
    Well done, quite a departure indeed from the mpcnc.
    What are you planning on cutting with this big guy. It seems like it could be ready for quite a variety of jobs.
  5. Jack Ethan Schlein
    Beast!
  6. William (Bill) McConnon
    Wow, very sturdy looking build. Do you have and idea on what the mass of the gantry and z axis will have on machine when doing rapid motions with directional changes. I ask because on my current machine (slightly modified x-carve) shakes the entire table when I get going to fast. Just curious. Again very nice and sturdy looking build.
  7. Gazza154
    Gazza154 New
    Great build,I would recommend if you havn't allready make sure you have ventallation or fan as drivers and power supply get warm.
