Can't install Open Builds Control 1.0.336
Discussion in 'OpenBuilds Bug Report' started by Daniel Rosman, Nov 14, 2022.
  1. Daniel Rosman
    I have 1.0.332 and works fine. I tried updating but it fails. It says that it can't close the program, but the task manager doesn't show anything opened besides the installation software. I tried also downloading it directly from the web. I run as administrator.
    Thank you
    Daniel
    Sometimes an old install can get a little corrupted. Try uninstalling, cleaning old files out of the previous install directory, then reboot, and try a fresh install
  3. Daniel Rosman
    I installed the .336 on a different computer and it worked fine.
    I tried to uninstall the .332 from the original computer with the problem and it told me that the software was open (it wasn't). I renamed the folder and installed .336 without problem. I tested and it works fine now. Something got corrupted in the folder. I will erase the old folder now.
    Thank you for your prompt reply. I like the dark profile and I'll take a look at the new controller
