About surface levelling
Discussion in 'CNC Mills/Routers' started by Lars Plovmann, Dec 14, 2022.
  1. Lars Plovmann
    Hi .
    jegfound the solution on my problem. a program call Open CNC - Pilot. work great.
    Hej alle.
    Jeg er ikke sikker på, at jeg placerer mit spørgsmål på det rigtige sted, men prøv:)
    Jeg har virkelig brug for at bruge overfladenivellering. Jeg bruger blackbox og kontrolsoftware og kan lide det, men kan ikke finde en måde at lave nivelleringen med grbl 1.1 Autonivellering kan ikke køre GRBL, Chilipeppr virker ikke desent på 1.1
    Hvad skal man gøre ?
    Jeg er ikke den store kodehaj, så det skal simpelthen være nemt at få til at fungere:)
    måske har du nogle tips:)
    hilsen
    #1 Lars Plovmann, Dec 14, 2022
  2. Alex Chambers
    If you mean mesh bed levelling (probing multiple points to map the surface) I don't think grbl can do that (I have no idea whether grblHal as used on the new blackbox X32 can). There are controllers that can (usually ones that have been originally developed for 3d printing) - the Duet range in particular, although originally developed with 3d printing in mind make excellent cnc controllers.
    @David the swarfer, @Peter Van Der Walt do you know if grbl Hal can do this - if so the blackbox X32 would be a solution.
  4. David the swarfer
    if you search for my postings on this topic you will find a link to an excellent video on how to use bCNC for this.
  5. Lars Plovmann
    jeg know some programs can do it o GRBL, and I found a program call OpenCNC pilot. It work :)
    jeg hope some day it will be in the control software :) I find Open cnc pilot. it work perfect.
    Thanks alot. But I find some program call Open CNC pilot It work perfect
    #5 Lars Plovmann, Dec 15, 2022
