Makerbase MKS DLC (v2.0) always disconnected
Discussion in 'Laser Cutters' started by Asasergio, Jan 30, 2021.
  1. Asasergio
    Asasergio New
    I recently received a Makerbase MKS DLC (v2.0) with MKS TFT35 display (v1.0) and then I updated the TFT35 firmware for laser (MKS TFT35_LASER v1.0.3) because laser is my goal.
    But I'm not getting access to the DLC, either through USB (Windows 10 does not recognize DLC on the port) or through TFT35 ("disconnected").
    The DLC motherboard always has the red LED on and the blue LED flashing.
    I changed the baud rate on TFT35 to the 4 possible values, always with the same negative result.
    Would anyone have any idea what may be missing or where I might be wrong?
  2. matthew A jones
    I'm currently running the mks dlc32 with the 35 screen. The red light is always on and the blue light flashes constantly when it's on. Have you downloaded and installed the ch340 drivers for your pc? These have to be installed for the pc tp recognize the controller.
