Black Box set up- Set Zero doesn’t visually change Coordinates
Discussion in 'OpenBuilds Forum Help' started by CNCHensley, Jan 8, 2023.
  1. CNCHensley
    I recently upgraded my Millright Carve King with an Open Builds Black Box. I have used the Open Builds CAM before and I like it. However, since installing the Black Box, when I reset my zero for any of the axis, it doesn’t change the coordinates visually.
    Any suggestions?
    Are you using OpenBuilds CONTROL?
    Did you use our CUSTOM.machine profile so the Reporting Options are set correctly?
  3. CNCHensley
    I am using the Open Builds Control and selected the Custom machine profile.
  5. CNCHensley
  6. CNCHensley
    Also, is it required to have an SD card installed? I can install
    That's incorrect
    Should be 511
    SD Card is optional
  8. CNCHensley
    Wow!!! That worked. Thank you very much sir. You guys are awesome!!!!!!
