blackbox controller and lego technic
Discussion in 'General Talk' started by roses, Jan 19, 2023.
Tags:
  1. roses
    roses New
  2. David the swarfer
    doubt it can do the motors, they are DC motors, right?
    the steppers will move but might be overpowered, I don'tknwo what the low end of the current adjustment is but it might stillb e too much for those tiny motors.
    Yes, one could add a resistor in series with each coil, which will reduce the heating, but may have strange effects on other motor parameters.
    roses likes this.
    Minimum is about 1.2A - likely too much for most NEMA8s I've seen. It's meant more for the NEMA17-23 range
  4. roses
    roses New
    hmm, I'm hoping to test out a NEMA 14 on the z axis to drive an acme thread, is that ill advised?
    Just checked the stats...
    • Nema 14 Stepper Motor with Step Angle 0.9 deg
    • Round, size diameter 36 x 12 mm
    • Holding torque 7 Ncm (9.91 oz.in)
    • Current/phase: 0.5 A and resistance/phase: 17 ohms
    #4 roses, Jan 19, 2023
    Way to small. 1.2A minimum (ideal for our 1.7A Max Nema17s). 0.5A max of yours needs more like 0.3A to run optimally. That figure is a Max rating, not a recommendation
    roses likes this.
  6. roses
    roses New
    Thanks! I've already tracked down a pancake NEMA17 that is rated to 1.2A so will use that instead
    Do again note, if its "rated 1.2A" thats the manufacturer saying "This is the absolute max - dare exceed it and it will be dead"
    Put 1.2A into continuously - and it will overheat like crazy. A 1.2A Max motor will probably like 0.8A, and even with that still burn your hand. Max rating is like the red line on your car's rev counter - you can't drive around at 6500rpm all day every day either. Just the same you can't run a stepper at Max Current. Ideal current setting would be lower than the maximum (always)
    BlackBox was designed as a power house. Give it a decent motor like ours: NEMA 17 Stepper Motor
    Not only is it rated to a max of 1.7A (making that 1.2A minimum setting a nice sweet spot for it) but also has low inductance (higher max rpm) and low coil resistance (fast acceleration)
  8. roses
    roses New
    Thanks, I will take that into consideration.
    It would be nice if the blackbox controller offered a way to even further drop down the current to the axis motors (Z axis in particular.) While I understand that a lot of people are using BB for CNC there are also uses for it where motor sizes could be scaled down.
    Understood, but at this point it is what it is - plenty of DRV8825/A4988/Pololu drivers based boards for the low end of the market - not much space for us
  10. jeffmorris
    jeffmorris Journeyman
    Lego motors are regular DC motors. I'm not sure about newer Lego motors.
  11. roses
    roses New
    True, although OpenBuilds is rather unique in that it provides a much higher quality and more complete solution (hardware/firmware/software/etc.).
