how to connect the laser
Discussion in 'Laser Cutters' started by Bober, Jan 24, 2023.
  1. Bober
    Bober New
    witam, jak podłączyć ten laser do blackboxa 12v?
    GND i PWM są znane, ale gdzie jest 12v
  2. Giarc
    You need a 12v power supply and it needs to share a common ground with the Blackbox like the Blackbox documents show.
    docs:blackbox-4x:connect-3-wire-laser [OpenBuilds Documentation]
    Unless of course there is some other board associated with the laser you are not showing us. The laser vendor should also provide information .
  3. Bober
    Bober New
    and after removing the jumper and setting $32=1 can I use the spindle normally?
  4. Bober
    Bober New
    skoczek
    $32=1 for laser, $32=0 for spindle. Remember to change according to the job at hand
    Bober likes this.
  6. Bober
    Bober New
    so you have to change it every time? depending on what is used?
    and pull out the jumper forever yeah?
    Jumper, no. Jumper is always removed. Only in place for Plasmas.
    $31 can be added to your CAM workflow. In the gcode header. Super easy
    Bober likes this.
  8. Bober
    Bober New
  10. Bober
    Bober New
    and for what purpose do you need to change $32 from 0/1
    because I don't quite understand
    if $32=1 the spindle will not run
    I have a makite milling machine
    Read the Laser Mode section of the Grbl Wiki
    Make sure your spindle is wired as per our documentation
  12. Bober
    Bober New
    ok, so to clear things up
    when i use milling machine i enter $32=0
    and when i use laser i enter $32=1
    I remove the jumper and it stays like this all the time without it
    Correct on all 3 points yes
