Heavier Router
Discussion in 'General Talk' started by Arthur pells, Jan 27, 2023.
  1. Arthur pells
    I have purchased the 800 W 110 V spindle. It weighs approximately 7 pounds is there any upgrade that needs to be done to the Z axis?
    If its the 65mm body air cooled, no upgrade needed. Wiring the spindle via a Swing Arm helps a lot to seperate the noisy VFD wiring away from low voltage cabling to prevent EMI
  3. Arthur pells
    Excellent thank you
  5. ozzy66
    ozzy66 New
    It depends on the specific machine you're using the 800W 110V spindle with. Upgrades to the Z axis may be necessary if the current setup cannot support the weight and power of the spindle.
  6. Arthur pells
    I have the spindle attached and is working ok but there is a bit of flexing. What kind of upgrade can be done to improve strength
  7. Giarc
    What machine is it used on?
  8. Arthur pells
    Open build 1515
  9. Alex Chambers
    What are you typically using for bit size, feedrate, spindle/router speed and depth of cut? If you push the machine too hard then you will get some flex on the X axis, especially with a 1500 long C-beam.
  10. Arthur pells
    1/4 bit 100 IPM 18000 RPM 3 mm deep stock Z axis
  11. Alex Chambers
    Those are perfectly reasonable settings. Is it the C-beam that is deflecting or the router/spindle? Two router mounts will help the rigidity - spaced as far apart as possible.
  12. JustinTime
    I use mostly about 1.5mm DOC at 100 ipm and my machine is REALY stiff and doesn't bent a bit.
