XYZ Probe issue
Discussion in 'CNC Mills/Routers' started by Adam T., Feb 15, 2023.
  1. Adam T.
    Adam T. New
    I ran a bunch of air cuts yesterday without issue, just getting comfortable with the machine. Today I was going to run my first cut, so I decided to hookup the XYZ probe, but it did not go through the normal steps of coming up and going to the sides and then the center hole. Sometimes it comes up and goes through one movement touches the probe for greenlight and then does nothing else but sit there. Also, since trying to setup the probe no job will even air cut, the same files that ran perfectly for air cuts yesterday before attempting to setup the XYZ probe plus. I get two messages at different times when I try to setup the probe, the messages are "error 2 - numeric value format is not valid or missing an expected value [T1M6]", "error 24 - Two g-code commands that both require the use of XYZ axis words were detected in the block. G0Z14].". I have cleared any job with a blank screen while trying to setup the probe and no job that air cut perfectly fine yesterday will do anything it just does nothing when I hit run job on any of the files. I can move and control the machine perfectly and it will rehome as well as go to any zero point I set it at.
  3. Adam T.
    Adam T. New
    It is the X32
  4. Adam T.
    Adam T. New
