Control 1.0.350 Wizard & Tools crash
Discussion in 'OpenBuilds Bug Report' started by Niclas Gudmundsson, Feb 21, 2023.
  1. Niclas Gudmundsson
    Just opened the open control software and it downloaded the new update.
    restarted everything and fired up the software. I was curious about the wizard things that was new, but as soon as I click on the "Surfacing / Flattening wizard" the program just freezes.
    installed the latest drivers for my GFX card and looked at windows update for any other update and made the updates available.
    restarted the computer and it still does the same thing.
    When you open the wizard, or when you proceed after entering parameters. If its the latter, you have some value set incorrectly or left empty. If however its the first one, let us know and we can dig deeper
  3. Niclas Gudmundsson
    The wizard window does not even open up, the program freezes before it even pops up. The dropdown menu is still open and can't get closed again.
    I have tried to reinstall but it didn't help. Even tried to install it on my windows 10 computer and its the same here. So 2 different computers and the same problem.
    Does work fine here, so that is odd.
    Open the Devtools (Ctrl+Shift+i) > watch the Console tab when clicking the menu item - see if theres any errors.
    Could also be that an earlier run of the wizard was ran with invalid data, we save last used values, so that could cause issues. You can clear that from Devtools > Application Tab > Local Storage
  5. Niclas Gudmundsson
    The last wizard I ran was with the previous version and that ran absolutely fine.
    I opened the console and ohh man, got a never ending log file. It seems to loop this all the time. I have a windows tablet with windows 11 and on my other PC I got windows 10 pro.
    The logfile I saved was 8Mb big of all text :D
    Give that one a go please, does look like something corrupted in local storage.
    Devtools (Ctrl+Shift+i) > Application tab > Local Storage > 127.0.0.1:3000 > Look for the "lastSurfacingTool" key and right-click > delete it. Hit F5 to refresh, then try the menu again.
    #6 Peter Van Der Walt, Feb 22, 2023
    Niclas Gudmundsson likes this.
  7. Niclas Gudmundsson
    Awesome!! This made it work.
    Thanks alot :)
  8. Lea23
    Lea23 New
    Today I updated the control software to the latest version (automatic update), I run the software and everything worked great until I tried to run the surfacing/flatting wizard, the control software then locks up and does not load the settings dialogue for the surfacing wizard and I have to close the program as all function is lost, I find this very strange but equally annoying but the software was fine until the latest update V1.0.353. Is this a known issue with the latest build? I'm running windows 10 which is updated daily. Is it possible to roll back to the previous version as I'm running my machine for my small business and depend on flatting pieces before carving?
    See Control 1.0.350 Wizard & Tools crash
    But if you could do me a favor - copy and paste your key here before you delete it so we can see if we can add improved detection of invalid stored key
    Lea23 likes this.
  10. Lea23
    Lea23 New
    That worked a treat, thank you for your quick response, all up and running again, Peter.
  11. Mike Maynard
    I had the exact same issue, did the dev tools reset and the wizard loads fine now.
    But after running the surfacing wizard about 3/4 of the way through it is throwing an error.
    [12:46:45] [ G1 X617.3000 Y277.3000 Z-0.793 ] ok
    [12:46:45] [ G1 X12.7000 Y277.3000 Z-0.793 ] ok
    [12:47:00] [ G0 Z10 ] ok
    [12:47:00] [ G0 X12.7000 Y12.7000 Z10 ] ok
    [12:47:00] [ ] error: 2 - Numeric value format is not valid or missing an expected value. [ G1 Z--0.793 ]
    [12:47:00] [ ERROR ] error: 2 - Numeric value format is not valid or missing an expected value. [ G1 Z--0.793 ]
    [12:47:00] [ G1 Z--0.793 ] error:2
    [12:47:30] [ ALARM ] ALARM: 3 - Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended. [ undefined ]
    [12:47:30] [ ] ALARM: 3 - Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended. [ undefined ]
    [12:47:30] [ ] ALARM:3
    [12:47:31] [ ] Grbl 1.1g ['$' for help]
    [12:47:31] [ ] [MSG:'$H'|'$X' to unlock]
    [12:47:32] [ ] Grbl 1.1g ['$' for help]
    [12:47:32] [ ] [MSG:'$H'|'$X' to unlock]
    [12:47:33] [ ] [MSG:Caution: Unlocked]
    [12:47:33] [ JOB COMPLETE ] Job completed in 00h06m
    The really strange part is the job keeps running until you click OKAY on the error and then it stops everything.
    I have done this twice now with the same result trying to surface a board.
    Luckily I could just restart the spindle and then jog for the little bit of the job left to finish.
    Can you post a screenshot of your parameters as entered? Possibly entered some negative numbers in the entry fields?
  13. Mike Maynard
    No negatives, and the settings are in line with what I normally use.
    Thanks will look into it
    Found bug, will be fixed in next update (possibly today or tomorrow) - thanks for the report
    Mike Maynard likes this.
    v1.0.354 available now - give it a test please
  17. David the swarfer
    I see 2 minus signs -- instead of -
    which is exactly what the error message is pointing out, invalid format of the number
    Already fixed, see above
  19. mike dauteuil
    running v1.0.354,was getting the freeze at tools/wizards.
    the fix above worked fine.
  20. Peter Van Der Walt
    Great. But please guys, next person - before your delete, just copy it out for us to investigate please :)
  21. Armaliteguy
    Latest build 1.0.363 Freezes EVERY time I simply click on surfacing wizard in the drop down. Only option is to force close.
  22. Armaliteguy
    It used to work fine on older builds. Other features in the same drop down work fine.
  23. Armaliteguy
    I dont have any "Last Surfacing Tool" within ANY of the "Localstorage"
    #23 Armaliteguy, Mar 22, 2023
  24. Armaliteguy
  25. Armaliteguy
    I don't have any of the such to delete yet still freezes.
  26. Armaliteguy
    I don't have a Local Storage > 127.0.0.1:3000 directory
  27. Peter Van Der Walt
    Please post a screenshot of Devtools > Application > Local storage > 127.0.0.1 showing all the keys, so we can see
  28. Armaliteguy
    Ok ,I was able to get it this time. what I have is.....
    {"surfaceDiameter":"22","surfaceStepover":"40","surfaceFeedrate":"2200","surfaceX":"690","surfaceY":"690","surfaceDepth":"0.1","surfaceRPM":"1000"}
  29. Peter Van Der Walt
    Thanks, providing this information, has helped indentify the bug, we have it fixed and released as V1.0.364 - see v1.0.364 · OpenBuilds/OpenBuilds-CONTROL@a33135a for the commit log
    It wasn't related to the recent addition of multipass cutting as suspected, but instead to the Coolant option that was added way back in v1.0.339 - so thanks for the help! Without the sample key we'd not have picked up the relation.
    You can either delete the key or update to v1.0.364 to continue working with the wizard
    Giarc and sharmstr like this.
