Interface "Go to X/Y/Z Zero" Axis Motor Movement Order
Discussion in 'Interfaces' started by GKTRK, Feb 26, 2023.
  1. GKTRK
    GKTRK New
    After I set work X/Y/Z zero position, if I have my cutter positioned well off and away from the workpiece, when I tap "go to XYZ Zero" the cutter moves to that location by operating all four steppers at the same time. This caused a crash the other day into my work piece and I had to E-stop and nearly broke the bit.
    Is there a way to re-order the movement in GRBL for this command so that it goes to X/Y zero at a safe Z height and then plunges? Or better yet to have a command/button on the Interface to just "Go to X/Y Zero" but NOT Z?
  2. sharmstr
    Click on the area next to "got to xyz zero" and select the second option. If you find that to be too much work, then create a macro for it and assign a keyboard shortcut to it.
  3. GKTRK
    GKTRK New
    Clicking the button to the Right of this command (top right of screen) simply sends the cuttterhead to XYZ zero - there is no option.
    I am running Interface V 1.51.
    #3 GKTRK, Feb 26, 2023
  4. sharmstr
    Sorry. Missed the "interface" in your title. I was speaking of Control.
    But similar suggestion. Add a gcode file to your usb drive that does what you want.
    GKTRK likes this.
  5. GKTRK
    GKTRK New
    Can I ask you for some help on that subject – I tried to make a simple warm up routine file like the one we have on our ShopBot but I keep getting errors? If I post it, could you take a look at it?
  6. sharmstr
  7. GKTRK
    GKTRK New
    This is the code:
    Code:
    M8
    M3S1000
    G4S120
    M3S5000
    G4S120
    M3S8000
    G4S120
    M3S10000
    G4S120
    M3S180000
    M5
    M9
    The Interface powers up the spindle and coolant relay and then they stay on and it gives a red error Will go grab a screenshot. Edit: "GRBL Error 28, Missing P or L Value."
    Assume I am missing something simple.
    Grant
    #7 GKTRK, Feb 26, 2023
    G4 uses a P-parameter, not S
    See G Codes
    sharmstr and David the swarfer like this.
