Limit switches always triggered (suddenly)
Discussion in 'Controller Boards' started by Artver, Nov 6, 2022.
  1. Artver
    Artver New
    Hi all,
    I have been running my machine for quite a while now. I have never had issues with my limit switches. But all of the sudden when I went to use it today, two of the three limit switches where constantly seen as "triggered" by the Blackbox controller.
    Please notice the following:
    1. I have not changed any wiring, the switches has worked for like 6 months with no issue
    2. I have tried turning off the computer
    3. I have tried fully unplugging the Blackbox controller (to remove power completely)
    4. I have tried the reset button (not sure exactly how that is supposed to work)
    5. I have tested the switches by moving the axis close enough to see the diodes turn on and then off when moved away again.
    6. I have tried unplugging the switches
    7. I have checked the wires, they are fine
    8. The x-axis switch works just fine
    9. As far as I can tell. The rest works fine.
    If anyone has seen this before, please advice.
    Martin
    Reset =restarts the firmware. Reboot.
    If they still show triggered even if unplugged, something damaged the Blackbox ports. Any miswirings, surges, etc you know about? Contact the store via https://support openbuilds.com > New Ticket. Any info of event around the limits that could have caused damage might just help with advice, so do let them know if you think of anything
  3. Artver
    Artver New
    Hi Peter,
    Thank you very much for your reply. I am trying to get in contact with the seller.
    /Martin
  4. djjester611
    i am now having the same issue on my X32 Black Box X axis. is the masking in the firmware correct or could i manipulate it to reverse the input
    Normally Open Switches : $5=0
    Normally Closed Switches : $5=7
