My Ox
Discussion in 'CNC Mills/Routers' started by Robert.sims, Feb 22, 2015.
  1. Robert.sims
    Robert.sims published a new build:
  2. GrayUK
    Looking good Robert. :thumbsup:
    If you haven't already done this yet, may I suggest you bolt the two "X" axis cross members together to increase strength and to reduce any chance of flex. :)
    Likewise, if you haven't already decided to, try using two belts for the "Y" and "X" axis. One on top the other.
    See: http://www.openbuilds.com/threads/fitting-dual-belt.1086/
    This helps eliminate any chance of stretch in the belt. :thumbsup:
    Two cheap, but sound methods, of improving the basic Ox. :thumbsup:
    Good Job
    Gray
  3. Robert.sims
    Hi Gray
    Thanks for the link.
    I haven't done that but it looks a good idea so I think I will order some more belt
    Bob
  4. sgspenceley
    sgspenceley Veteran
    Your build looks great Robert, have funt cutting something special!
  5. Robert.sims
    I will if I can get the axis,s setup the x and the y are not playing ball .
    set the Z up no problem
    Bob
  6. Robert.sims
    I have just had a thought I may be wiring the motors up incorrectly.
    I have mine wired as bipolar parallel. should they be bipolar series?
    any body help out there please.
    bob
  7. Robert Hummel
    Robert Hummel Custom Builder
    Moderator
    I would suggest parallel but both should work, what drivers are you using? Sorry if you already stated
  8. Robert.sims
    Hi Robert
    I am Using
    DQ452MA on the Z
    and
    CW230 on X and Y
    I have nema 24 425oz 3 amp on all axis 1.8 deg 1/8 (1600) microstep
    Bob
  9. Robert Hummel
    Moderator
    I would first change up to 1/16 due to the fact you have the power in your motors in turn you should see smoother operation.
    Second running the motors in series increases winding resistance lowering the motors current rating.
    Run them parallel for taking advantage of their full specs
  10. Robert.sims
    Hi Robert
    I will give that a try tonight.
    Bob
  11. Serge E.
    Serge E. Journeyman
    YourOX is looking good ... Did the kit also include the table as I see it is also using V-slot or similar extrusion ?
  12. Robert.sims
    Hi Sarge
    No the board didnot come with the kit. I made it out of 3/4 MDF.
    holes drilled at 50mm centres and the blind nuts hammered into the underside.
    Yes I am using Vslot it came in the kit.
    Bob
    @Robert Hummel
    "I would first change up to 1/16 due to the fact you have the power in your motors in turn you should see smoother operation.
    Run them parallel for taking advantage of their full specs"
    robert
    Did that and it made no difference.
    So I had a cup of coffee and a think.
    Why did the Z axis work OK and not the others?
    So I stripped down the contol box and put the z driver onto the x axis hey presto it worked.
    I then had a closer look at the driver for the x and y.
    :banghead::banghead::banghead: the clever chinese used "0" for on and "1" for on for the dip switches. So I was running the motors at .9 of an AMP.
    My fault I should read the instructions first.
    Bob
  13. Robert Hummel
    Moderator
    Lol well know that with them wired par you will be taking full advantage of your motors :)
    Good to hear you solved it, always a little thing that puts a wrench in the mix :confused:
  14. Tweakie
    Tweakie OpenBuilds Team
    Moderator
    Hi Bob,
    I have forgotten who it was that first said " If all else fails, read the instructions " but with the Chinese to English translations it is not always that easy to understand. Nevertheless I am pleased you found the problem and have it sorted. :thumbsup:
    Tweakie.
  15. Robert.sims
    thanks Tweakie
    i wont know till the weekend if it all works ill let you know
    bob
    sgspenceley likes this.
  16. Robert.sims
    It's alive
    it works thanks to you all for your help.
    I have just got to figure out how to load videos now
    bob
    GrayUK likes this.
  17. GrayUK
    Congrats Robert. :thumbsup::thumbsup:
    May you have many happy hours making chip!!
    Gray
  18. Robert.sims
    Cheers Gray
    now to finish of
    limit switches,
    estop
    ETC
    now to strip it down as the extra belts have just arrived.
    bob
  19. sgspenceley
    sgspenceley Veteran
    Congrats, chips away!
  20. Robert.sims
    Hi All
    The first phase of the build is complete. Rails screwed together, double belts fitted, (Thanks Gray) Estop and limit switches done. bracket for water cooled spindle made and fitted.
    The first job the machinne did was to make the brackets to hold the switches.
    All seems to work fine.
    Now to make my guitar.
    #20 Robert.sims, Mar 22, 2015
    GrayUK likes this.
  21. Robert.sims
    Mark Carew, Robert Hummel and GrayUK like this.
  22. Tweakie
    Moderator
    :cry: It was a good effort though. ;)
    Nice work with that Outrunner. :thumbsup:
    Tweakie.
  23. GrayUK
    Looks really good Bob. :thumbsup::thumbsup:
    Don't be a stranger, even it all goes well. :D
    Go for the Chips!! :nailbite:
    Gray
  24. Robert.sims
    Hi All
    It's been a while but I have been busy at work.
    I have made a few things on the OX . But now I needed to make a couple of curcuit boards.
    so i needed to make a proper bracket for the Brushless motor.
    so made one on my 3D printer.
    here are some pics.
    I will upload the sketch and the STL if anybody is interseted
    All the best
    Bob
  25. Mark Carew
    Well done Bob!
    What are your thoughts on the outrunner vs. the VFD spindle?
    Thank you for sharing these awesome pictures :thumbsup:
    Mark
  26. Robert.sims
    Hi Mark thanks for the kind words.
    I haven't had chance to use the VFD for long as I have a problem with Mach 3 tripping I have tried all the usual
    cures but have not had much luck yet. I will keep trying.
    as for the outrunner it seems to be excellent I have made a couple of signs with it without a problem.
    now i have made the proper bracket for it I plan to use it more. I also use a router which has given me no problems.
    Except noise
    Bob
  27. Robert.sims
    Hi All
    I am after some advice please.
    I am about to start cutting some aluminnium plate on the OX and i am looking for some advice on feeds and speeds.
    the cutter is a 4 flute 6mm dia end mill the plate is 3 mm thick.
    Can someone advise on the feed rate of the cutter for this aplication.
    Bob
  28. Paruk
    Paruk Journeyman
    Hi Robert, Mark posted a link under resources about cutting aluminium. Read it before you start with it. Forget about the 4 flute! It won't get the chips out, resulting in melting material into your bit and BANG! says the bit. Max 2 flute, preferable 1 flute with an OX I would say. The rest you can find in the feed & speeds of CNC cookbook.
    GrayUK likes this.
