Update not working??
Discussion in 'Control Software' started by 10ftsamsquanch, Mar 15, 2023.
  1. 10ftsamsquanch
    Just installed the newest update and now the controll software wont open. anyone else have this issue?
    What OS are you running?
  3. John Haymann
    YES. Auto update hosed me on this one. All I get is a white window. Clicking does nothing.
    OK! Thanks for the better problem description: Deleting 1.0.361 :)
    Roll back to 1.0.360 please: Release v1.0.360 · OpenBuilds/OpenBuilds-CONTROL will push out a fix later today as 362. 1.0.361 was a quick test for a Linux specific issue
  5. John Haymann
    Windows 11. Previous version worked flawlessly.
  6. 10ftsamsquanch
    That worked. thanks
    That question was aimed at the person above you. I replied to yours with more info.
  8. sharmstr
    Peter fyi incase you dont have the error yet.
    statusCode: 200
    (node:17716) electron: Failed to load URL: http://localhost:3000/ with error: ERR_CONNECTION_REFUSED
    (Use `electron --trace-warnings ...` to show where the warning was created)
  9. John Haymann
    Thanks!
    Any way to turn off auto update? Trying to avoid it hounding me every hour.
    it won't - 1.0.361 is deleted. "latest" is 1.0.360 again, which you are on. There is nothing newer to update to.
    Yes! I accidentally commited with the temporary Port (3200 vs 3000) in there from when I was testing your issue. Not a biggie - just a crazy morning.
    Already rolled back! v1.0.361 · OpenBuilds/OpenBuilds-CONTROL@17d8f51
  12. sharmstr
    .362 (NOT RELEASED YET) is working on debian and windows. Cant check mac.
