How to use more than one probe
Discussion in 'General Talk' started by Jayhawk714, May 23, 2023.
  1. Jayhawk714
    I know you can use different probes with the X 32 Black Box, however, I have no idea how to wire/connect/switch them. I looked through the documentation but did see any info how to do that. Do I just connect the two in the Probe switch on the back of the x 32?
    If both are Normally Open, you can parallel them yes.
  3. Jayhawk714
    Thanks again, Peter!! Hope you like to answer questions because I have a feeling until I get used to OpenBuilds I will be asking plenty!!!! :);)o_O
