drilling and milling stainless steel sheet on a mini mill
Discussion in 'CNC Mills/Routers' started by mp1001, Jul 3, 2020.
  1. mp1001
    mp1001 New
    my first cnc hole (with a lip), done on a mini mill (in stainless steel sheet :jawdrop:) . I might remachine it with a much smaller finishing pass - see if I can improve on the slight, albeit uniform, imperfection on the corners. It might be the best tolerance the machine can do, yet - I guess I'll find out !
    (Milling is of an ABS-backed 1mm stainless steel sheet using a 90 Degree Point, 2 Flute, Micrograin Carbide
    AlTiN Coated drill and Carbide 2 Flute AITiN-coated End Mill )
    Corner radius is 3.35mm, drill/mill diameter 6mm
    #1 mp1001, Jul 3, 2020
  2. Giarc
    Looks good! Better than my first unintentional attempt at stainless. It was a piece mixed in with aluminum off-cuts at my local metal yard...and I assumed it was brushed aluminum. I even checked it with a magnet. :rolleyes: The part worked, but it wasn't pretty.
    mp1001 likes this.
  3. Lisandro
    Lisandro New
    Were you able to improve the stainless steel machining? Could you share the parameters that you used? I am interested in machining some SS in my new minimill.
    Thanks!
