Modified parameters
Discussion in 'General Talk' started by AdriSan, May 31, 2023.
  1. AdriSan
    AdriSan New
    Hi, I am new here. I hope you can help. I have a CNC workbee 1510. I use it with the Black Box4x and the interface CNC Touch. Every time I run a design in Aspire or any other design software, the size is modified. In the Open Builds control screen the size shows up correctly, but when I run the CNC the size is reduced approximately by 20%.
    I've also tried carving the "hello world" sample design and it is reduced as well. I don't know what is happening. I appreciate your help.Thank you
    AdriSan and David the swarfer like this.
  3. AdriSan
    AdriSan New
    I appreciate very much your help, it worked!
