what are the icons on the X32
Discussion in 'General Talk' started by Jayhawk714, Jun 3, 2023.
  1. Jayhawk714
    Can someone direct me to a picture or diagram of the 7 icons on the front of the X32. The print on the x32 is so small I can not read them! :( I would be happy even with the names of them. :)
    Thanks!!
  2. Giarc
  3. Jayhawk714
    I have looked at every picture at your link many times. Can you just tell what the icons are? Apparently your eyesight is so much better then this old man's are.
  5. Ray Jenkins
    • From lt to right above the current adjusters for each axis.
      c) Status LEDs
      • Door LED: On when the Door input signal is active
      • Tool On: Indicates the Tool is Enabled
      • Tool PWM: Shows the proportional RPM or output power of the PWM/0-10v outputs
      • Coolant LED: Shows status of the Coolant signal (M8 = on, M9 = off)
      • Probe LED: Lights up when the Probe Input activates
      • Motors Enabled LED: Indicates when the firmware has the Motor Drivers Enabled. In Grbl Settings set $4=0 (required for BlackBox X32 drivers to function correctly) and $1=255 (to keep motors always enabled)
  6. Jayhawk714
    Oh Thank you!! That's all I needed. At 72 my eyes just can't read print 1/32" or less. :):( And thank you for the Grbl settings. I will check that out in the morning.
  7. Jayhawk714
  8. David the swarfer
    Peter that list in the docs is missing the spindle direction light (6 listed, 7 lights)
    and that image is not exactly readable, needs about 20% more dots (-:
    yes, I tried to edit the wiki myself, seems I have forgotten the password and the password reset does not like my username, did it expire?
