Version 1.0.369. Updated
Discussion in 'General Talk' started by Rick Hamilton, Jun 7, 2023.
  1. Rick Hamilton
    Now mobile jog widget doesnt work with latest update??
    You can try V1.0.370, but even 1.0.369 works for me: Definately a phone problem / network / etc
    Give it another go, making sure to force-refresh the page (You can still see the old blue title bar theme there - thats very old!)
    and make sure the computer's IP hasn't changed from 192.168.0.7 to something else (If you had the wrong IP your browser may be bringing up an old cached version of the HTML but of course missing CSS and JS and websocket etc - its not designed to run from offline cache)
    Also make sure you are on the same network
  3. Rick Hamilton
    Dont know but its just that version.
    Went back to the previous version and everything works perfectly…
    Open that version and same thing. Mobile jog widget doesnt load or work
    Did you try 370?
  5. David the swarfer
    worked for me on both versions but what it did do is choose the wrong network.
    I have a virtual network adapter (tailscale) and it chose that as the target, but my phone can't get to that (I have not installed the client yet, dont need it on the phone).
    output from ipconfig
    Code:
    Windows IP Configuration
    Unknown adapter Tailscale:
       Connection-specific DNS Suffix  . : tailxxxxx.ts.net
       IPv6 Address. . . . . . . . . . . : xxx
       IPv4 Address. . . . . . . . . . . : xxx.yy.bbb.ccc
       Subnet Mask . . . . . . . . . . . : 255.255.255.255
    Ethernet adapter Ethernet:
       Connection-specific DNS Suffix  . : place.of.work
       IPv4 Address. . . . . . . . . . . : 146.aaa.fff.jjj
       Subnet Mask . . . . . . . . . . . : 255.255.255.0
    Ethernet adapter vEthernet (Default Switch):
       Link-local IPv6 Address . . . . . : yyy
       IPv4 Address. . . . . . . . . . . : 172.qqq.ttt.iii
       Subnet Mask . . . . . . . . . . . : 255.255.240.0
    I don't know what the 3rd one does but that would also have been a wrong selection, the middle one is the real ethernet adapter.
    bit of an edge case but something to be aware of when facing connection issues ... does the IP address make sense?
  6. Rick Hamilton
    No…..
    368…
    Well then:
  8. Rick Hamilton
    I get updates, its a love hate relationship. when you busy just trying to finish a clients project I need it to just Work!. Ill dig in when I get a chance. Appreciate the insight and assistance….
    Im sure everyone gets into the same situation sooner or later..
    Gotta get the customer job done now, figure out software / issue later… for now just go back to what was working.
    Any plans to add a bit setter to a known position?
    My other Cnc it finishes the current job and moves up and middle to the front of the machine for you to change to the next tool, then moves to the bit setter height lowers down to measure the new tool height and moves to the next tool path for that tool with perfect Z zero
