Openbuild Cam not generating code
Discussion in 'General Talk' started by joefroooo, Jun 12, 2023.
  1. joefroooo
    joefroooo New
    Im usually pretty good at figuring this stuff out but a new control problem is driving me nuts.
    Ive loaded a SVG in to OpenBuilds cam generator and pick closed lines for cutting. I create the tool paths and get the 4 green check marks to transfer to openBuilds control. When control is open on the newest version V1.0.370 nothing is there. This is using Mill with offset inner and outer paths. Now if I choose laser vs mill it generates code. Can someone give me a clue to what to look for please.
    Joe in St Louis
    Please post the workspace export so we can check for you: CAM > File > Export Workspace .OBC
  3. joefroooo
    joefroooo New
    Here is my SVG and the saved G code. Dont thing there is any code since sending to control nothing is there. IMG_4075.jpg IMG_4077.jpg IMG_4078.jpg IMG_4079.jpg IMG_4080.jpg
  5. joefroooo
    joefroooo New
    When looking at control there is a image of a box to the left bottom of my cutter. Is that normal or is my origin off??? I also get no simulation in CAM even tho says generated a code.
    Sounds like you forgot to home, or didn't set Homing up correctly
    Not related to the CAM issue. Post the export so we can see what your parameters were. Will check it (if you do post it) tomorrow
  7. joefroooo
    joefroooo New
    Is that the same as the G code I posted ?
  8. joefroooo
    joefroooo New
    Ill check That but I still cant Simulate after getting the 4 checks to send to control, The cutter and the path doesnt show.
  9. joefroooo
    joefroooo New
    Here is saved as OBC named it bad file
  10. Alex Chambers
    No, Please post the workspace export so we can check for you: CAM > File > Export Workspace .OBC, as @Peter Van Der Walt said.
  11. joefroooo
    joefroooo New
    it is in the post above your reply Alex #9 post
  12. joefroooo
    joefroooo New
    Is there anything you see in the OBC file that would cause my problem?
  13. joefroooo
    joefroooo New
    Peter i still have not figured out why, can you look at the file and see if it is something i did wrong, Ive tried drawing some random shapes and still have the problem. Some of my old saved files still work my machine. Thanks for the help sorting this out
    You set Cut Depth Start to 2mm, and Final depth to 2mm. You can't start and stop at the same depth. Set start to 0 - thats more useful if you want to mill a deeper pocket inside an already made pocket for example - save some time starting at the bottom of the previous pocket.
  15. joefroooo
    joefroooo New
    How strange, I didnt put that in there , I will change and cut. That explains why i have the issue with new files. thanks and happy cutting
    Joe
  16. joefroooo
    joefroooo New
    Peter here is a gold star for your help. Worked out. Wish I was 1/100 as smart as you on this.
    Joe
