(2) Y Motors one "Y" plug in
Discussion in 'General Talk' started by Dancook, Jun 21, 2023.
  1. Dancook
    Dancook New
    I unplugged my control board and forgot to take pictures of where the stepper motors plugged into. Each driver has an actual plugin for each stepper motor, the plugins on the board are labels "A", "Z", "X" and "Y". I can follow each wire to its place on the control board. My problem is I only have one"Y" plug BUT to "Y" stepper motors. Not sure how to plug in (2) "Y" motors. When I use my "A "plug to plug in my extra"Y" stepper only one side of my CNC works. Something is very wrong here. Are there any experts out there that can help me.
  2. Giarc
    We don't use an A label, so perhaps xPro. If so, 2nd Y motor plugs into A
  4. Dancook
    Dancook New
    I am building the Worker Bee 1000. I switched out both Y motors and the Y plug works with both motors but the A one gets no response
    What controller do you have?
  6. Dancook
    Dancook New
    I’m running mach3 I noticed that the “A” driver had red wire running to B- AND BLACK RUNNING TO B+. Switch them around but still nothing. I think it was originally wired correctly so I’m going to switch them back. All the other drivers are wired red to B+and black to B-. These are lol brand new drivers
  7. Dancook
    Dancook New
    I’m running Mach 3 off of my laptop using my arrow keys
  8. Gary Caruso
    mach 3 is software, what model drivers/hardware are you using? a pic could be helpful as well.
    Gary
  9. Dancook
    Dancook New
    Here it is
  10. Dancook
    Dancook New
  11. Dancook
    Dancook New
  12. Gary Caruso
    Ok that helps, so you should see from the controller board Y-Pulse and Y-Direction signal wire running to both Y drives, in parallel, trace those wires and troubleshoot.
    Make sure you are getting power to both drives and and they are lighting up, should be a power and or enable LED on them.
    Make sure the dip switches are set the same on both Y drives.
    Gary
  13. Dancook
    Dancook New
    I can configure the “A” driver as a slave and it will activate the y axsis on the left side while the right side is separately activated by a separate key. I know the “A” driver has power since I can activate it. Dip switches are exactly the same
  14. Dancook
    Dancook New
    After tracing the wires from the A driver they are going to the “A” side of the control board. My “Y” driver wires are going to the Y side of the control board. I do notice that my B+ and B minus coil has been flip-flopped on the “A” driver compared to the white driver
  15. Dancook
    Dancook New
  16. David the swarfer
    I think you also need to tell Mach3 to pair Y and A to make them move together
  17. Gary Caruso
    I always thought A was used for rotary axis on mach3? Is the machine setup for dual home switches? I'm sure it's possible to use A for Y2 but unless you can do Y1,2 homing independent wouldn't it be easier to parallel the output from Y to both drives?
    Was this machine working fine before the disassembly?
    Gary
  18. Dancook
    Dancook New
    That I can’t answer. The person that had it before me had it built for him said he never used it but was able to manually move all the axis’s
    How do I tell Mach 3 to pair both motors? Or parallel both together. I’m new at this game but know enough to be dangerous.
  19. David the swarfer
    I dont know how to do that, perhaps the Mach3 forums/documentation will answer that?
    Machsupport Forum - Index
  20. Peter Van Der Walt
    Or wiring the Y output from the BoB in parallel to both drivers might be easier
  21. Dancook
    Dancook New
    So that would be running the pulse and direction wires from both drivers to the Y axis on my bob. Is that correct?
  22. Dancook
    Dancook New
    If that is the case how do I run 2 wires into the same plug-in when there is only room for one wire
  23. Peter Van Der Walt
    Twist them together and insert. And use appropriate sized wires, its a 20mA signal so 0.2mm2 is plenty
    If you really have to, split it up a couple inches away into a Y.
    Or... Easiest option of all, get a BlackBox (https://docs.openbuilds.com/blackbox-x32 no need to wire up all the little bits, proper documentation and videos etc. Well worth it)
  24. Dancook
    Dancook New
    If I went that rout I would have to change my laptop to a 32 bit instead of my 64 bit. I’m going to try to contact Mach3 and see if I’m missing something simple in my configuration here if that doesn’t work I will run both drivers through the Y port on my bob. Thanks
  25. Peter Van Der Walt
    Huh, why? :eek:
  26. Dancook
    Dancook New
    Well reading up on blackbox32 it only can run on a 32 bit system cost 239.00 + another laptop ,say 200 .roughly 500.00 . Adjustment in Mach config (if there is one in Mach 3 I don’t know about is free and I can keep everything as is.
  27. Dancook
    Dancook New
    I do think I can use smaller wire like you said an accomplish what I want without splitting my power to each stepper and my burn up my driver by over load. I don’t wan6 to run both motors off one driver . That sounds real iffy
  28. Peter Van Der Walt
    Of course not you are just splitting the step/dir/enable signals between two drivers
  29. Dancook
    Dancook New
    I take it that they will run square with each other as well or will I have to step one up? I’m using the same nema motors
  30. Gary Caruso
    I think you are confusing power wires from the motor with the signal wires coming from your controller board.
    Move the signal wires from the bob A channel and land them the same way on the Y channel of your mach3 board.
    If the ferules on the wires make it so you can't fit both just cut them off and twist together the two signal wires. The motor power all comes from the drivers not the bob.
    Also the reason one of your motor pairs are swapped around is to reverse one of the Y motors. Swapping any one pair of wires (one coil) will change the direction the motor runs.
    If your machine is belt driven you would need one motor reversed.
    OR
    I found this video quick about mach3 setup, about 11:30 mark they discus channel assignments, might help.
    Gary
