I am new to open builds.
Discussion in 'Control Software' started by Mikki Robinson, Jun 30, 2023.
  1. Mikki Robinson
    I have a custom build and I am using a 32x controller. When my x and y move they show 80 mm when in fact they have moved over 380 mm. here are my settings
    controller 4x
    machine acro 1010
    x axis 700mm
    y axis 700 mm
    z axis 100 mm
    please give me some direction
    Did you remember to select the Acro from the Grbl Settings tab in CONTROL > Select machine from the list > Save and Reset when Prompted?
    As its not quite a Acro we'll have to fix Z homing (Set $44=7, and $45=0) afterwards as well as Z-steps-per-mm (200 if its our leadscrew)
    After initial setup you should be closer, then fine tune using the Calibration wizard under Wizards and Tools
  3. Mikki Robinson
