LINEAR RAIL SPHINX 55 (Blue OX plates)
Discussion in 'CNC Mills/Routers' started by that-jim, May 2, 2020.
  1. Steve Hall
    Hi That-Jim,
    I have been looking at your build and I am currently starting my own build of a similar nature.
    Apolgies for quoting metric, are you using 4080 C beam extrusion.
    If so, what size of ball screw and nut did you use as I am struggling to find ball screw flange nut that will fit in the 40mm space of the extrusion.
    Thanks - WoodKnot
  2. that-jim
    that-jim Journeyman
  3. Steve Hall
    Thanks JIm -
    I thought i may get away with a thicker ball screw than that?
    However, now i have seen the simplicity of the nut, i may still be able to use my 16mm screws and get something machined up in the UK?
    Steve
  4. that-jim
    that-jim Journeyman
    I don't think that the nut for a 16mm ball screw will fit in the c-beam, perhaps if you build a custom nut block. The other consideration is the pitch of the screws and the motor/controller you plan to use. The openbuilds leadscrew, c-beam, motors and black-box are a plug and play type of solution.
  5. Rhett E
    Rhett E Well-Known
    What would be the benefit in utilizing ball screws instead of lead for this machine? Speed, accuracy, etc...? Would the cost and labor justify the change?
  6. Rob Taylor
    Speed/acceleration, mostly. much lower friction for a given level of backlash. Can run smaller motors because less power is lost as friction. Price isn't that much different any more, ball screws got really cheap.
    Backlash can be just as substantial as lead screws though; DFU nuts are required to get almost-zero-backlash operation, which is particularly important if you're using a control that doesn't provide even basic single-value backlash compensation, like grbl. So that costs more. Some vendors offer "anti-backlash" screws which is where the nut's been emptied and repacked with slightly oversize balls, which take up more room between the two channels and allow for less "slop". They do help, but they're not magic.
    Accuracy/precision is largely the same as lead screws; "C7" doesn't really mean anything, once you've actually mapped screws you see that the true pitch varies wildly as you move along the screw, which is almost certainly the case for any rolled screw, leadscrews included. Ground screws (ball- or lead-) cost serious money though; you could build an entire machine for the price of a couple of ground screws. There are happy mediums, of course, C5, C3, etc. You get meaningful precision guarantees then.
    If you're unsure, want to use off-the-shelf OpenBuilds type products more or less as-intended, and don't want to deal with any additional work combating backlash, lead screw is probably the way to go. If you want significantly higher performance, the possibility of far higher rigidity and power put into the tool instead of the machine (12mm and 16mm screws are enormous compared to 8mm), and are willing to build your machine to the specifications required to actually use that additional performance without simply bending your machine frame, then ballscrews are awesome.
    Rhett E likes this.
  7. that-jim
    that-jim Journeyman
    Good quality ballscrews will be more accurate but the openbuilds lead screws are really very good and appropriate for a build like this. the lead screws also work well with the openbuilds motors and controller and are easy. I was plenty happy with the lead screws for this build.
    Peter Van Der Walt and Rhett E like this.
  8. Rhett E
    Rhett E Well-Known
    Thank you both for the responses. I currently have a lead 1515 but I'm looking to downsize the footprint. I'm leaning towards modifying it similar to this setup and still utilizing my blackbox and other parts.
  9. Redouane Saidi
    Brilliant build, Thank you.
    Would it work if I were to make it bigger, using 1000mm C-Beam Extrusions? I'm worried about the deflection of the gantry by the weight of the spindle and Z-Axis
  10. that-jim
    that-jim Journeyman
    My guess is that at 1000mm wide it would be reasonable for wood and plastics similar to a lead 1010. I built this at the smaller size because I primarily wanted to use it for aluminum and it works good for that. If you are planning on a large spindle and or cutting metal you might look at something like the double beam on the 1515 or some other reinforcement.
    Someone might post a reference to how to calculate deflection, so keep in mind that the above are my un-engineered opinions.
    Redouane Saidi likes this.
  12. Redouane Saidi
    Thank you, I'll do some more research on it.
  13. Dewberry
    Dewberry New
    Great Build, very well executed! I have the same plate set and have finally gotten back to finishing it after a long, long hiatus.
    I have a few questions if you dont mind:
    1) What length are you using for the 2060 extrusions that make up the base? I just used 474 (500mm - 13mm*2 for the mgn12 rails/blocks on each end) Just wanted to confirm my thinking is correct.
    2) On that note, what dimensions are you using for your mdf spoilerboard?
    3) Also if you could share the STLs for your 3d printed induction sensor mounts and your printed drag chain bracket, that would be awesome
    Much Appreciated and again, great build
  14. that-jim
    that-jim Journeyman
    I think your math is correct, this is spacing that I have on my machine.
    my waste board is a 3/4 slab of mdf with threaded inserts and on top of that I have a 1/2 mdf that matches the cutting surface so it looks like this.
    I will attach files for the printed parts and wasteboard to the build.
  15. that-jim
    that-jim Journeyman
    I added the quite a few files to the files and drawing section of the build, hopefully you can use them.
  16. Ray Jenkins
    I am going to try a 600x600 build. Would 640mm lead screw’s be long enough? Also, if I were to use Chris’s 11inch plates, do the z pieces need to be longer?
  17. Redouane Saidi
    You would need about 30mm to satisfy the build, so I'd say 640 is enough though you'll have about 10mm more but I'd say it won't hurt, good luck Chris's 11inch plates cause I don't know about that.
  18. that-jim
    that-jim Journeyman
    a 640mm screw should work, I think the 250mm z would work with the 11 inch, my build uses the 9" plates and I had travel that I could not use with a 250mm z. I ended up doing an upgrade to my z you can see it here. link
    #48 that-jim, Mar 4, 2023
  19. Ray Jenkins
    If I actually complete a working machine, I now know what my 1st aluminum project will be. That is a great looking z.
  20. MapleCreekVermont
    This build looks awesome and will be the inspiration for my first cnc build. One question I have is that looking at the pics it looks like your base frame is different than the sphinx 55 frame. Am I seeing correctly that there is only a piece of 2060 front and back of the machine? Another question not specific to this build is, how do folks cut multiple lengths of extrusion precisely say I want 3 lengths at 800mm how can cut and have precision accuracy in length and squareness. Thanks.
  21. that-jim
    that-jim Journeyman
    There is more to the frame under the bed than the pictures show, somehow I did not get a good picture of it. It looks like this.
    I have cut these extrusions with a chop saw and got great results. The key to the set up is to have some sort of stop you can repeat the same cut. Clamping the extrusion to the saw while cutting also helps with squareness. I have a saw stand like this at home and I can get great results with it. In most cases it is more important that the lengths match than any particular measurement. You might be able to rent a saw for a day from the big box stores. I have also cut extrusion on my table saw with a cross cut sled and got perfect 90 degree cuts. I am not sure if openbuilds will do custom cuts, maybe they can chime in.
    MapleCreekVermont likes this.
  22. MapleCreekVermont
    Thanks. One other question I have: on the original sphinx build the x axis is 3mm longer than the width of the frame. Is that correct? Why is this necessary? Are spacers used and provided with Chris’ plates, and what is the reason the frame can’t just be narrower?
  23. that-jim
    that-jim Journeyman
    The x-axis beam is wider to accommodate the height of the rails and bearing blocks that mount to the outside of the frame. I don't remember this measurement but I can look later today at mine and give it to you.
    The spacers included with Chris's kit give you the correct spacing between the inside of a gantry plate and the anti backlash nut.
  24. that-jim
    that-jim Journeyman
    The height of a MGN12 rail and bearing is 13mm, so you the c-beam for the x will need to be 26mm wider than the frame.
  25. MapleCreekVermont
    If I use a stock length extrusion for the x (1000mm) could the frame just be 26mm narrower than that since the parts of the frame that run parallel to the x axis are the ones that get cut to a custom length anyway?
  26. that-jim
    that-jim Journeyman
    Yes, this would work.
  27. MapleCreekVermont
    Thanks that actual clears up a lot of confusion for me.
