Gauthali V2.0 DIY 3D printer
Discussion in '3D printers' started by Raju Chohan, Aug 22, 2023.
  1. Raju Chohan
    Raju Chohan published a new build:
  2. JustinTime
    I would suggest not to use the gussets to support the uprights but to use a flat aluminum (or something similar) triangle. It will be much more solid and, most importantly, much more precise in keeping the construction square. 2mm or 3mm will be plenty enough to accomplish this.
    Christian James likes this.
