Cube 3 / Pro hacks
Discussion in '3D printers' started by eychei, Jan 16, 2017.
  1. Tom Dirriwachter
    Tom Dirriwachter Well-Known
    You can't but 2.00 you can. It takes a install interrupt and it has reported issues. I might point you to the ReCube option for re-filling cartridge chips. DIY or eBay. Also nice to program chips to exactly what you put in the cartridge. Saved my bacon more than once. Good luck.
  2. Venda
    Venda New
    Thanks a lot, I ordered ReCube. You save my machine;)
    Tom Dirriwachter likes this.
  3. Shahak
    Shahak New
    HI :)
    While trying to open the fimware file on the CubeTollbox im getting this message : "error patching fimare" , any help ?
  4. Smashadalek
    i have a slight issue i installed the unpatched cube v1.14B.ar file to my cube 3 and now when i go to firmware and select usb key and then i plug my usb with the new patched cube v1.14B.ar.orginal file and it says firmware download failed, what do i now? is it due to my usb as i am using a different usb to when i first installed the firmware or do i need to reset my cube 3 if so how do i go about doing that?7
  5. buddybu
    buddybu New
    is the file named cube v1.14B.ar.original?
  6. Smashadalek
    yes the file in the usb is called cube v1.14B.ar.original, wait hold on i think ive just realised i need the new cube v1.14B.ar file which is created at a guess.
  7. Widgex
    Widgex New
    I got an ekocycle from my robotics team a few days ago and found this mod. I do not have any software for the printer to download prints or make them and the link posted on this thread for it now says "access denied". Also how would I use this stop counter mod on my ekocycle? Do I tear it apart and find the SD card and modify the hex values or would I use the site that isn't working and modify the hex values there and put it on the ekocycle.
  8. Maxaye
    Maxaye New
    Hey Widgex, just started going down the rabbit hole with this whole thing about 24 hours ago. If you'd like I was able to find an original working program to slice the files, Cubify, I believe the original software. This is where I found it. PART1_A-E - Google Drive I used cubify_3.04.exe and was able to print a little Easter Island Head no problem.
    Still working with some folks on how I can get the spool chip to freeze.
  9. Maxaye
    Maxaye New
    Hey Chief, like a donkey I went and gave my Ekocycle a flashing screen loop. When you say you pulled the SD card and replaced the Image695.hex file with the one from the unpatched .ar file, could you explain what that means? I have a modified .ar file and an "original" .ar file but am unclear how to get the Image695.hex. Thanks.
  10. dirkie1
    dirkie1 New
    hi all is there a way to use simplify 3d to make g codes for cube 3 ?
  11. buddybu
    buddybu New
    Not easily. I believe there is one for CubePro, but I don't know how usable that is for Cube3 (if at all).
  12. Tom Dirriwachter
    Cube3 uses a proprietary and unique bias heating routine. You would have to add that in post processing. For every M104, you need to add a new line that is M204. Basically, Cubify heats nozzle 1 with help from nozzle 2 typically in the 155C range. The reverse is true also, of course.
    buddybu likes this.
  13. LUdo1232
    LUdo1232 New
    how to download the firware???
  14. buddybu
    buddybu New
  15. SavageGoat
    Any idea on how to print fully solid parts, not the useless almost solid setting?
  16. federicovl
    hi im having trouble im looking for firmware update for cubify cube first gen i need a .hex file cant find it anywhere
  17. decanfrost
    Help please...
    I can not get any slicers to see my Cube 3 (stock 1.1.4b and on modded FW)
    Shows up in Device manager as Com9 serial to usb.
    Tried via WiFi and it says connected after selecting my wifi and password but ip always shows as (168.254.1.1 .. windows null address)
    Tried using a wifi adapter on my pc in Adcock mode ip shows as 192.168.1.3 it will connect for 3 seconds thr disconnect
    No apps see any of these 3 connections.
    What am I missing here
  18. federicovl
    hi imnew at this but when i tried to open the link with a regular bwoser it trows me to a tab that says " This XML file does not appear to have any style information associated with it. The document tree is shown below. " i used this link: https://cubify.s3.amazonaws.com/Printers/Cubepro/cubepro_1.87.exe to get the file location but i don't really understand what an XML type of file is :/ i tired to find out if i have to use a diferent browser that supports that type of links but im confused
  19. jsputnam
    jsputnam New
    Question: Anyone have the 2.00 firmware for the Pro? I have 2.02 installed on my printer and want to use the hack. Thanks.
  20. jsputnam
    jsputnam New
    NM, found it.
  21. Nicolás Neto
    The link doesn't seem to be working. I cannot download the files. Anyone can help here?
  22. Tom Dirriwachter
    These things have disappeared from the 3D Systems servers. We have an archive on the print3dforum - 3DS Cube File Links
  23. Nicolás Neto
    great. Thanks a lot
  24. Ashes
    Ashes New
    It seems print3dforum is down. Does anyone have the printing software?
    blitzkrieg_vt likes this.
  25. Ashes
    Ashes New
    I was given this on Reddit.
    3DS Cube File Links
  26. ayrezxxx
    ayrezxxx New
    Hello I have a problem.
    They gave me a Cube 3 printer, when I turn it on it asks me to register it on the cubify.com website, when I enter it redirects me to 3dsystems.com/support/cubify but it won't let me register it because since July 2023 are no longer supported. Does anyone know what can I do? Is there a code generator?
  27. Tom Dirriwachter
    Contact 3D Systems support. They usually help with this type of issue.
    I also have a printer that the last 4 digits of the serial number is the code. YMMV
  28. ayrezxxx
    ayrezxxx New
  29. Tom Dirriwachter
  30. oppo210
    oppo210 New
    Yup, now when you contact support for a pin code, they want you to pay them $129 to provide a 4 digit PIN. Any way we can by-pass the activation? Guessing the code is gonna take a while.
