Python Connection to Blackbox grbl and sending G-Code
Discussion in 'Control Software' started by domio, Aug 28, 2023.
  1. domio
    domio New
    Hi there,
    I'm trying to establish a connection to grbl on the X32 blackbox through the serial port. I haven't found anything that works out of the box. I'm not sure what I am missing. Maybe you could help me debug this, so I can have a working sample on GitHub that we can refer users too.
    Right now, it's stuck at "Sending: b'\r\n\r\n'"
    My basic understanding of initialization would be something like this:
    1. Wake up grbl → '\r\n\r\n'
    2. Reset errors → '$X'
    3. Homing → '$H'
    4. Send G-Code → 'G1 X100 Y100 Z0.0 F5000'
    The project is on GitHub: grbl-python/demo.py at main · dottenbr/grbl-python (github.com)
    Code:
    #!/usr/bin/env python
    import serial
    import time
    # Open grbl serial port
    s = serial.Serial('/dev/tty.usbserial-AQ02Z8ND', 11520) # put your serial port here
    print('Connected to: ' + s.name)
    print('Serial port open: ' + str(s.is_open))
    # Serial write and readline
    def send_gcode(gcode):
        s.write(str.encode(gcode))
        print('Sending: ' + str(str.encode(gcode)))
        print(s.readline().strip().decode('utf-8'))
    # Wake up grbl
    send_gcode('\r\n\r\n')
    time.sleep(2)   # Wait for grbl to initialize
    s.flushInput()  # Flush startup text in serial input
    send_gcode('$X') # Reset errors
    send_gcode('$H') # Homing
    send_gcode('G1 X100 Y100 Z0.0 F5000') # Go to X:100, Y:100, Z:0.0 at 5000 mm/min
    # Close serial port
    s.close()
    domio and David the swarfer like this.
  3. domio
    domio New
    Thank you for the hint, the baud rate was obviously wrong.
    I fixed that, and I also realized that I was missing the carriage return '\n'. I have updated the code on GitHub and I have now included a jog mode with which you can use the arrow keys to move the head as well as homing, centering and going to zero coordinate.
    I hope this helps other people who are trying to communicate with Black Box through Python.
