Relay 1 problem
Discussion in 'CNC Mills/Routers' started by pablomatraka, Aug 31, 2023.
Tags:
  1. pablomatraka
    Hello, I am new to cnc and I have already made a serious mistake, a few days ago I burned my router doing a profiling and well, I have changed it for an identical one but I have a problem, I have connected it and it does not start. I have checked the wiring and it is fine, the router works if I connect it directly, but apparently relay 1 does not let power pass, I have rewired connecting relay 2 but I don't know how to make it detect this new configuration, could you help me.
    i have a black box x32 on a router with laser
    Well, Relay1 is not documented for use in any of those devices (Router nor Laser)
    Can you post some pictures of your wiring please
  3. pablomatraka
    hello, this is my wiring. Forgive the precariousness of the image.
    You are running MAINS through a low voltage signal relay! This is DEADLY! No no no. Please please remove immediately and follow the documentation provided on docs.openbuilds.com/blackbox-x32
    (relay 1 would likely be burned out already, glad no one died and nothing caught fire!)
