Techsoft Roland TS-30 rebuild
Discussion in 'CNC Mills/Routers' started by ewr2san, Sep 6, 2023.
  1. ewr2san
    ewr2san New
    ewr2san published a new build:
  2. Mark Carew
  3. ewr2san
    ewr2san New
    Some starting Photos. Factory Spindle and Factory Electronics:
    The original spindle still works but has an older and less ideal tool system. I prefer having a collet based system, so I'm leaning towards replacing the under powered spindle with a 500W one.
    Have disassembled the old spindle, and CAD'd some adapter plates to use a 52 mm spindle. 3D printing a dummy spindle to decide if it works.
    I'll either retain the 3D printed (5 walls, PETg) motor mount or CNC the aluminum mount that ships with the spindle. We'll see if it's rigid enough (should be, depends on how hot the spindle gets I may use CIM motor coolers..)..
    Those 500w DC "spindles" are terrible. Just a super cheap brushed DC "motor" with a collet attached using grubscrews (off center, not a press fit). Vibrates like crazy. Don't waste your money!
    If it can fit, try a RoutER11 CNC Kit
  5. ewr2san
    ewr2san New
    Interesting.. I thought the DC spindle would have less runout and vibration than a "Mini Router" based spindle. I have a dewalt 1.25hp spindle on a V1 Lowrider. It's decent for what I use it for (Wood mostly, 6061 occasionally). I wish it had a little less vibration and runout, and a speed controler that integrated with GRBL.
    Is there a speed controller for the RoutER11 that meshes with GRBL?
  6. ewr2san
    ewr2san New
    I don't see dimensions anywhere.. So if I assume "nearest 5 mm", 65mm diameter for the body tube:
    A rough CAD using the images on the website as a canvas yields:
    Fusion
    (I have asked the OB store if they have actual dimensions or a .STEP)..
    It "should fit"... I will definitely need to machine (or 3D print) an adapter to the face plate. Any feedback on how hot the RouteR11 runs?
  7. ewr2san
    ewr2san New
    More progress today.. Openbuilds store gave me a .stl and a sketchup of the RoutER11, and I think it should be workable. It will mean losing a few MM on the Y axis (probably 17-22 mm), but I can fix that with an oversized spoil board (thus no loss of build volume) on the front of the gantry.
    I have found the wiring for the X & Y end stops. Which oddly enough Look to be Reed Switches:
    The X and Y home in the right places (X=0, Y=0) to re-use the reed switches, so for now intending to re-use'em. The Z limit isn't working so Im doing a lot of continuity testing.
    Now for the truly odd part.. The Z stepper motor. It seems to have a solenoid that engages and disengages (Edit, it seems that it's a Z Break.. When engaged it stops the Stepper from spinning. probably owning to the 3.2V stepper having poor holding power):
    That isnt the oddest thing.. 3.2V stepper motors.. Well I guess I'm in for another $60 to get some 12-24V NEMA 17's..
    #7 ewr2san, Sep 7, 2023
  8. David the swarfer
    that is probably because they were running very high current through the motor and then turning the driver off to let it cool, the lock keeps it in place.
    Looks like a gearbox on there, that means the motor needs to turn really fast to get speed on the output, more voltas and amps needed for that, therefore more heat.
    I would remove the lock mechanism. if the motor gets really hot, fan cool it if needed (obviously reduce current first)
    eh? almost, but not quite, no such thing. (-:
    low voltage, and low inductance is what you want in a stepper. The drivers in the BlackBox take in 24v and pulse it to control the motors and limit the average current.
    You WANT 24v on the motors (which are actually rated for 1 to 3 volts, I see the OB page lists 12-24v, trying to reduce confusion I guess)), because that enables higher max speed (due to complicated electrical stuff inside the motor).
    Specs like these ones if you are not buy in from OpenBuilds NEMA 17 Stepper Motor
    ewr2san likes this.
  9. Alex Chambers
    RoutER11 (RoutER11 CNC Kit) comes with a 71 > 65 mm adapter sleeve.
    I have one and it's much superior to a palm router - better bearings, ER11 collet and much quieter than a palm router.
    ewr2san likes this.
  10. ewr2san
    ewr2san New
    Excellent @Alex Chambers I have ordered the RoutER11 (along with some steppers) more about that below:
    Quite a bit of clever engineering all around on this machine..
    The factory 3v steppers had really weak holding power(around 0.5KG-CM). They were geared up 10:1 giving a holding force around 5KG-CM. The Openbuilds steppers spec at 5.5 KG-CM so they should to the job.
    The rebuild will make this machine a lot simpler.
    Took apart the X axis today and I'm waiting on some GT2 pinions (and spindle and good steppers):
    After removing the old stepper (sorry no pic):
    Drilled out the old center hole to 1/4in.
    Then 3D printed an alignment block and used that together with some CNC Table Tape and a clamp to drill the first of 4 holes to mount the stepper:
    Once the first hole is drilled Put a screw through the hole to make sure the block doesnt move. Then Drilled the other 3 holes (total of 4). A 90 degree Drill extender is handy for that.
    Then mounted a stepper (not the ones I want to use just one lying around):
    Seems super stable, well centered, and should do the trick once more parts arrive.
    Mounted up the 3D printed Spindle Holder (PETg, 5 walls, 15% Gyroid infill, and captive nuts):
    I've used 3D printed spindle mounts before on MPCNC, and LowRider and as long as the Spindle stays relatively cool it should work.. If it doesn't I'll machine a better mount out of Aluminum.
    #10 ewr2san, Sep 9, 2023
    David the swarfer and JustinTime like this.
  11. ewr2san
    ewr2san New
    Waiting on a lot of parts to show up. Meanwhile doing the electronics.
    Crimping on dupont connectors to the X,Y,Z stepper wires, and to the endstops. Looks like I will have X = MIN, Y=MIN, and Z=MAX endstops.
    There is a nice jack for a probe, figure I'll wire that as a Z=MIN endstop or to the probe on the GRBL...
    Added a USB type B extender.
    Need to print a mount for a Meanwell 24V supply, and some buc converters. Nice thing is this has a nice E Stop already wired in on the front that will get wired to kill the Arduino, PS, and Spindle.
    Leaving room for a speed controller based on an Arduino nano. How easy is it to hack the RoutER11 to use PWM? If not I'll fake out the potentiometer with an I2C Digipot...
  12. ewr2san
    ewr2san New
    Well, a lot has changed.. Found out that I probably could have re-used the "3.2v steppers" on the X axis.. Once my 24v supply was connected up, the Y drove just fine at 24v. I may put the X back to the orignal design or leave it.
    But I've got it cutting (highly un-optimized, still need to set 1/2 stepping on X, feeds and speeds, enstops, etc..)..
    simple bespoke gcode to cut a 20x40mm rectangle out of a paint stir stick:
  13. ewr2san
    ewr2san New
    A lot of things puzzled me for a while and have had a lot of re-design and re-work.. But it's now cutting and working and I'm in the tinkering and tuning phase.
    Some not fun things that baffled me for a while:
    1. GRBL CNC Shield or Drivers were flaky on Y axis.
    2. Driving the Z at rated current overheated the stepper on Z.
    3. Bad existing wires on Y.. cut 1/2 way through..
    4. Z axis wasnt holding well when steppers disengaged.
    Which led me to a few things:
    1. Redesigned Z for a geared Leadscrew. 3D printed Herringbone gears & rod give me 800 steps per mm (vs 40 with the ungeared). Holds like a champ, works nicely.
    2. Abandoned the GRBL board. I had a RAMBO Einsy from a PRUSA MK3S+ that has been converted to a MK3.9 (all new electronics). So the PRe-USeA is born..
    3. Re-wired most everything with the Nice wire that was included with the OpenBuilds NEMA 17 steppers.
  14. Mark Carew
    Wow @ewr2san you did a great job on getting this badboy back on its feet and to be honest better then ever. Adding the lead on the z its a great upgrade in itself!
    Nice work thanks for sharing this rebuild with us
  15. ewr2san
    ewr2san New
    Added some Air Assist, and an LED Light (loose coonnection in the video).
    Cutting Alumuninum at Dial #4 and FPT of 0.002 IN (18,400 RPM 75 IPM, tiny DOC). Safe settings to start and it's certainly rigid enough:
    Video:
    and it's certainly accurate (30x30 cut):
    Next up more feeds and speeds tuning, then posting all the CAD files for the pieces I 3D printed...
  16. TheForgottenKing
    I'd like to join this thread. I have an identical machine and am going to do much of what OP did, except I plan to keep the original steppers and only change out the electronics. I'd also like to keep the spindle since mine works fine.
    OP, would you mind providing more details and progress as to what works/doesn't work?
    #16 TheForgottenKing, Jun 11, 2024
  17. ewr2san
    ewr2san New
    Hello @TheForgottenKing ,
    I am really happy with the rebuild. I don't regret any of the choices made, and it now machines 6060 aluminum nicely. The stock spindle is really under powered, and I really like the RoutER-11 spindle upgrade a LOT. Highly recommend.
    The stock steppers are under-powered and even at high current struggled to keep accurate steps at reasonable feeds and speeds. I'm happily machining PCB Boards, Acrylic, Lexan, wood, and 6060 Aluminum with no issues at all.
    Start with the Electronics, then decide what you want to re-build.
  18. ewr2san
    ewr2san New
    I've put some time into tuning since March, and use tmc sensorless homing for X & Y, built a g-code sender handheld with buttons, and am working on a touch screen based G-code sender. I ended up re-using an Einsey Rambo Board as the new brains, and I am preferring Marlin Based CNC to GRBL.
  19. Dimitri Kulker
    Hello, congratulations on your work, I also want to reuse the EINSY from my MK3 and the motors, but to convert a proxxon FF230 to CNC. I want to use MARLIN also! Can you provide more information about the button to control the CNC ? Thank You ! Dimitri
  20. ewr2san
    ewr2san New
    The button to control it is a Raspberry Pi with a milled PCB with buttons running a python script
    Code:
    import board
    import digitalio
    import busio
    import time
    import serial
    try:
        print("Attempting Serial Connection")
        s = serial.Serial('/dev/ttyACM0', 250000)
        print("Serial Connected")
    except:
        print("Serial Connection Failed")
    try:
        print("Sending CR")
        s.write("\n".encode())
        print ("Flushing Input")
        s.flushInput()
        print ("Reading")
        out = s.readline()
        print(str(out))
        s.flushInput()
        print("Serial initialized")
    except:
        print("Failed to Send")
    # define buttons x+/-, y+/-, z +/-, zero XYZ, zero z, Fast, Medium, Slow
    button_xp = digitalio.DigitalInOut(board.D6)
    button_xm = digitalio.DigitalInOut(board.D19)
    button_yp = digitalio.DigitalInOut(board.D26)
    button_ym = digitalio.DigitalInOut(board.D13)
    button_zp = digitalio.DigitalInOut(board.D4)
    button_zm = digitalio.DigitalInOut(board.D5)
    button_zeroxyz = digitalio.DigitalInOut(board.D11)
    button_zeroz = digitalio.DigitalInOut(board.D0)
    button_slow = digitalio.DigitalInOut(board.D9)
    button_medium = digitalio.DigitalInOut(board.D10)
    button_fast = digitalio.DigitalInOut(board.D22)
    # set all buttons to input & pull up
    button_xp.direction = digitalio.Direction.INPUT
    button_xp.pull = digitalio.Pull.UP
    button_xm.direction = digitalio.Direction.INPUT
    button_xm.pull = digitalio.Pull.UP
    button_yp.direction = digitalio.Direction.INPUT
    button_yp.pull = digitalio.Pull.UP
    button_ym.direction = digitalio.Direction.INPUT
    button_ym.pull = digitalio.Pull.UP
    button_zp.direction = digitalio.Direction.INPUT
    button_zp.pull = digitalio.Pull.UP
    button_zm.direction = digitalio.Direction.INPUT
    button_zm.pull = digitalio.Pull.UP
    button_zeroxyz.direction = digitalio.Direction.INPUT
    button_zeroxyz.pull = digitalio.Pull.UP
    button_zeroz.direction = digitalio.Direction.INPUT
    button_zeroz.pull = digitalio.Pull.UP
    button_slow.direction = digitalio.Direction.INPUT
    button_slow.pull = digitalio.Pull.UP
    button_medium.direction = digitalio.Direction.INPUT
    button_medium.pull = digitalio.Pull.UP
    button_fast.direction = digitalio.Direction.INPUT
    button_fast.pull = digitalio.Pull.UP
    # set initial movement increment based on speed
    # actual speed is increement / debounce (+ some delay)
    slow_increment = 0.1
    medium_increment = 1
    fast_increment = 10
    move_increment = slow_increment
    # set debounce time
    debounce = 0.5
    def move(axis, distance, debounce):
        print("G91\nG0 {0}{1} F300\nG90\n".format(axis,distance))
        try:
            s.write("G91\nG0 {0}{1} F300\nG90\n".format(axis,distance).encode())
            out = s.readline()
            print(str(out))
            s.flushInput()
            print("Command Sent")
        except:
            print("Failed to send Command")
        time.sleep(debounce)
    def zeroxyz(debounce):
        print("G92 X0 Y0 Z0\nG0 Z1 F300\n")
        try:
            s.write("G92 X0 Y0 Z0\nG0 Z1 F300\n".encode())
            out = s.readline()
            print(str(out))
            s.flushInput()
        except:
    def zeroz(debounce):
        print("G92 Z0\nG0 Z1 F300\n")
        try:
            s.write("G92 Z0\nG0 Z1 F300\n".encode())
            out = s.readline()
            print(str(out))
            s.flushInput()
        except:
    while True:
        if button_xp.value == 0:
            move("X", move_increment, debounce)
        if button_xm.value == 0:
            move("X", -1 * move_increment, debounce)
        if button_yp.value == 0:
            move("Y", move_increment, debounce)
        if button_ym.value == 0:
            move("Y", -1 * move_increment, debounce)
        if button_zp.value == 0:
            move("Z", move_increment, debounce)
        if button_zm.value == 0:
            move("Z", -1 * move_increment, debounce)
        if button_zeroxyz.value == 0:
            zeroxyz(debounce)
        if button_zeroz.value == 0:
            zeroz(debounce)
        if button_slow.value == 0:
            print(move_increment)
        if button_medium.value == 0:
            move_increment = medium_increment
        if button_fast.value == 0:
            move_increment = fast_increment
    #20 ewr2san, Jun 20, 2024
  21. ewr2san
    ewr2san New
    It's really rough around the edges, and I need to work on it a bit more.
    Was mostly a proof of concept. I'm working on a better version that uses a TFT touchscreen and a Pi W. More customizable, and easier to use.
  22. Dimitri Kulker
    Nice! Do you have the config.h file for Marlin to adapt it for the Rambo board for your CNC? I am at this step.
  23. ewr2san
    ewr2san New
    Looking for it.. Have an older one, but I seem to be missing the latest..
  24. ewr2san
    ewr2san New
    These are from 5/13/2024 and missing one or two little annoying fixes, but should get you 90% of the way.
    Marlin-rambo-einsey-CNC/Marlin/Configuration.h at bugfix-2.1.x · mperino/Marlin-rambo-einsey-CNC
    Marlin-rambo-einsey-CNC/Marlin/Configuration_adv.h at bugfix-2.1.x · mperino/Marlin-rambo-einsey-CNC
    These are for Marlin 2.1.2.2 You may need to diff them against current config files, or use 2.1.2.2.
    Some things off the top of my head..
    Sensorless Homing is enabled for XY.
    Added a zero-ing menu to the top level.
    Current is set to 1.3a, 1.3a and 1.25a which worked nicely with the openbuilds NEMA 17 steppers (not too hot, plenty of juice to prevent lost steps).
    When you select any Z Zeroing, it zero's Z then moves up 1 mm.
    You'll have to change steps per mm for your build.
  25. Dimitri Kulker
    Thank you very much, it's moving!
    ewr2san likes this.
