Openbuilds control stops mid job.. for no apparent reason.
Discussion in 'Control Software' started by Peter Sesselmann, Sep 12, 2023.
  1. Peter Sesselmann
    I have recently moved from a "Crashing" and "Problematic" Windows PC to a MacBook Air for running the control software. The MacBook is dedicated to running Control, and does not need to do any other task.
    I have the latest OS and the latest Control software.
    On some random jobs it will simply stop at some point. the monitor show that gcode has stopped. if I click on the pause button and then click on continue > it will go one step forward, if I pause again and press continue it will go one more step forward, about 3 times then it will not respond. Also when I do this I don't see any gcode changes. I then have to reboot Control and reset 0 and start the job from the top.
    I have tried to do some troubleshooting but I am coming up short.. When I first started using the MacBook everything worked perfectly. For some reason I now have problems, I can't remember what happened before the problem started ie, updates etc..
    Has anyone here had similar problems??
    Peter Sesselmann likes this.
  3. David the swarfer
  5. Peter Sesselmann
    Hi Peter, thanks for the reply.. I suspected there might be interference.. so I moved the USB cable away and use a ferrite on the cable.. it does happen mostly when the Router is closest to the controller.. would a shorter USB cable be better?
  6. David the swarfer
    shorter USB cable is ALWAYS better (-:
    2 feet is a nice length
  7. Peter Sesselmann
    is there recommended distance for the laptop and blackbox to be from the CNC machine.. my laptop and blackbox are about 2 feet away from the Cnc...
  8. Peter Sesselmann
  9. Peter Sesselmann
    So far so good! New driver! New cable! New ballasts…
