Laser speed not increasing
Discussion in 'General Talk' started by Jayhawk714, Sep 17, 2023.
  1. Jayhawk714
    I am having a problem with my J Tech laser and I do not know if it's an OpenBuilds, J Tech or Lightburn problem. No matter what I increase the speed the laser goes the same slow speed. I did 4 videos using the same 9" line file. All speeds are in inch/min. The burns were made at 70,137,200 and 223 and all are within a couple of seconds of each other. Around 28 seconds. The X belt is tight and I am at a loss as to what is going on.
    Forgot to say this is on a Inventables X-carve 1000.
    #1 Jayhawk714, Sep 17, 2023
    Have a read through the Grbl Wiki, might be Max Rate see Grbl v1.1 Configuration
  3. Jayhawk714
    Thanks Peter, I will look at that when I get out to the shop.
