Sienci Labs Vortex Rotary Axis
Discussion in 'General Talk' started by rscamp, Sep 24, 2023.
  1. rscamp
    rscamp Well-Known
    Is there any technical reason (outside of mechanical fit) why the Vortex Rotary Axis couldn't be added to an Openbuilds machine with a BlackBox X32?
    Not familiar with it, but do check its motors electrical specs (voltage, inductance, resistance)
    rscamp likes this.
  3. rscamp
    rscamp Well-Known
    Thanks Peter.
    It looks like the motor is probably a LDO-57STH56-2804AC.
    • Rated Voltage 2.5V
    • Current /Phase 2.8A
    • Resistance /Phase 0.9 Ω
    • Inductance /Phase 2.5 mH
    • Holding Torque 12.6 kg.cm
    • Number of Leads 4
    • Rotor Inertia 300 g.cm^2
    • Stall Torque 0.4 kg.cm
    I haven't compared this to your motors yet.
    That should run fine :thumbsup:
    rscamp likes this.
  5. rscamp
    rscamp Well-Known
    Cool. Thanks!
  6. rscamp
    rscamp Well-Known
    On a related note, is there a released or beta OpenBuilds F360 post that supports a 4th (rotary) axis?
    rscamp likes this.
  8. rscamp
    rscamp Well-Known
    Awesome!
    For BlackboxX32 based on ESP32 for grblHAL with 4th axis
    Made possible by
    Swarfer GitHub - swarfer/GRBL-Post-Processor: Start
    Sharmstr https://github.com/sharmstr/GRBL-Post-Processor
    Strooom GitHub - Strooom/GRBL-Post-Processor: Post Processor for Autodesk Fusion360, delivering GCODE output optimized for GRBL compatible CNC or Lathe
    This post-Processor should work on GRBLhal-based machines
    longDescription = "MultiAxis post for Blackbox X32 with single rotary axis A or plain XYZ."
    Still in Beta, but yeah should get you going
  10. David the swarfer
    make sure you read the popup help in the post options dialog, if you select the wrong stuff, it won't work correctly.
    if you don't set up a machine configuration a default one will be used, which may not match your actual machine.
    rscamp likes this.
  11. rscamp
    rscamp Well-Known
    Thanks for the tips, David.
