Tabs in operation not showing up in G-code
Discussion in 'CAM' started by Jimius, Jul 29, 2019.
  1. Jimius
    Jimius New
    I'm using the openbuilds cam to generate a vector with a 1 pass final depth cut with tabs. The tabs however are not generated or shown. Even when going to a 2 pass cut it won't show. Am i doing something wrong?
      File size:
      98.7 KB
      55
    Tabs are done on multiples of a pass. So if you have 1 pass 8mm deep, you cannot have a 4mm deep tab. You can either run 2x 4mm passes, or have a 8mm high tab
  3. Jimius
    Jimius New
    Thanks for the reply. However I've tried both methods before, without result. The folowing settings do not generate tabs for me.
    At this time, I would recommend playing with values till it does: (or post the workspace export, screenshots alone may be pointing at the wrong thing, for example, maybe its a circle and there is no straight sections long enough to put the tab in, or you need to play with tab width/spacing - trial and error needed sometimes)
    Works for me:
  5. Jimius
    Jimius New
    There are no straight edges on the shape I'm trying to cut. I guess that is the problem. Thanks for the help!
    Indeed, need a segment long enough to fit an endmill, and the width of the tab you want, to place it in :)
  7. mO Cooper
    mO Cooper New
    So openbuild project will not have tabs unles it’s all straight lines?
  8. Alex Chambers
    It can only have tabs if it has some straight lines. Can't put a tab on a curve.
    Not all straight no. But somewhere a straight little section that meets the required distance to fit a tab with the parameters you provide (which you can play with - smaller tabs, or closer spacing etc)
    play with the numbers - it will honor what you tell it to. If you have a 25x25x25x25mm square but set spacing between tabs to 100mm - it can't place one because the entire cut length is less than spacing+tabwidth.
    Post a workspace export and I'll check your setup for you (File > Export Workspace in OpenBuildsCAM)
