unable to genetrate gcode with openbuild cam
Discussion in 'CAM' started by matchboxx, Oct 11, 2023.
  1. matchboxx
    matchboxx New
    hi it was working at first then now i cant seems to generate gcode. it will get stuck at calculating
  2. matchboxx
    matchboxx New
    here is my workspace
  3. sharmstr
    That's OK, and doesn't affect Gcode generation. Been disabled as a feature since Disable Integration · OpenBuilds/OpenBuilds-CAM@100acae though the old Certs in CONTROL may still throw errors in console, not an issue
    Rightfully so, You can't cut at 0mm depth per pass :) - put in an actual depth to cut and it will be able to compute a toolpath for you
  5. sharmstr
  6. matchboxx
    matchboxx New
