lost my ability to move router on XYZ.
Discussion in 'General Talk' started by JimKramer, Oct 15, 2023.
  1. JimKramer
    JimKramer New
    I created a toolpath on v-carve and neglected to set my z-gap above material. Z-gap above material was set for 1 inch. When I started the job it went down into some MDF rapidly. I stopped the job. After that I lost my ability to move my router in xyz direction.Could I have blown a power supply or my blackbox? Are the indicators or test points I can check for voltage?
  2. David the swarfer
    reset the Blackbox and run the home cycle, should be fine after that
  3. JimKramer
    JimKramer New
    I did a reset on the black box and I got my XYZ movement back. Not sure what a home cycle is but it looks like i'm good to go. That was perfect. Thanks.
