Interface, no wifi
Discussion in 'General Talk' started by cabrasauce, Oct 19, 2023.
  1. cabrasauce
    Using Blackbox V32 with the interface. I have been trying to set it up for hours now and still nothing.
    After following the setup instructions the pop doesn't come up and http://192.168.4.1 doesn't work. I have tried numerous phones as people have said but that's also no help. I tried updating via my computer, flashing via software options, updating via usb. All don't work. All I get to see is a worthless game on the front screen. Also, holding MODE to get into flash mode just puts you on test mode no matter how long you hold it.
    You have to connect it to the Blackbox first
    Follow the documentation step by step. Wifi setup is the step AFTER connecting it. Successful connection implied. You can't load the setup until Interface is up and running (if it fails to connect, it is indicating that onscreen and after several minutes drops you into the game to keep you busy)
    Follow docs.openbuilds.com/interface step by step, don't skip ahead until the relevant step is complete
  3. cabrasauce
    I was able to connect it. I did connect it to the blackbox but I'm thinking i didn't push it in all the way.. Everything seems to be functioning and updated. BUT The interface will restart if I'm traveling the y axis straight back for maybe 4 + seconds straight though.
    Are you using our power supply or a 3rd party? Any other 3rd party components involved?
    Did you follow all the Important Note sections of the Documentation?
  5. cabrasauce
    I followed step by step with every direction and note section. I'm using only open builds components, other than the router its self.
    Thanks for confirming, please contact the store via Support > New Ticket
  7. Dane Austin
    Do you have your computer hooked up the blackbox while you are trying to use the interface? It is one or the other.
