roughing and finish not linning up
Discussion in 'General Talk' started by Jayhawk714, Oct 23, 2023.
  1. Jayhawk714
    What would cause this problem? Would it be that the roughing and finish tool paths not lining up? The job was built in Vectric x-carve desktop. Zeros where set using OpenBuilds Control probe-plus in the lower left corner.
    Roughing used 1/4" end mill, finish used 1/8" ball nose bits.
    No need to reprobe X and Y when swopping tools. Zero is already set. Swop bits and rezero Z only.
  3. Jayhawk714
    Ok, no probe when swapping bits. So just lower Z until it reads 0 or until it touches the material?
    No, you can Probe Z after replacing the bit, just don't Rezero XY - as the centerline of all bits are the same, but their lengths differ.
  5. Jayhawk714
    Got it, thanks Peter.
