Using Openbuilds as Laser Controller - Arduino and Ramps 1.4 with Marlin Firmware
Discussion in 'Laser Cutters' started by Mert Can, Oct 25, 2023.
  1. Mert Can
    Mert Can New
    Hi everyone. I made a DIY laser cutter using arduino and ramps board. I'm using Marlin firmware. I was use the Lihgtburn software for laser control and gcode sender. But now, the trial time is expired. Can I use OpenBuilds software like Lightburn? I want to control my laser on my computer. Can anyone help me?
    Thanks a lot.
  2. David the swarfer
    no, CONTROL will not talk to Marlin.
    You will be much better off with a Blackbox, much better drivers, standard GRBL firmware, OpenBuildSCONTROL, our fusion360 post, our Vectric post. many advantages.
    BlackBox Motion Control System X32
  3. Mert Can
    Mert Can New
    Thanks for your answer.
