Usb thumb drive
Discussion in 'CNC Mills/Routers' started by Mark R, Nov 3, 2023.
  1. Mark R
    Mark R New
    Hi y’all
    So I ordered some USB thumb drives. They are 16 Gb fat 32 and 4096 formatted . I also ran the Wizard on them to add the files needed . When I insert them and try to use them I get a error and thee interface locks up and needs reset to get it to ddi anything. So I ordered some 8gb drives went through the whole process again and same thing. Any ideas what is going on here ?
    Thanks in advance
    Mark
    Does the drive included with the Interface work? If it does, it might be incompatible drives in some way, but if the included one doesn't work contact the store via Support > New Ticket
  3. David the swarfer
    4096 sectors?
    maybe the interface is expecting 512 byte sectors?
  5. Mark R
    Mark R New
    The USB supplied does work. I guess they just are not compatible. I have a micro 8MB fat 32 with adapter that I use on my 3d printer that works so who knows . Thanks for the suggestion
  6. Mark R
    Mark R New
    Update 1 bought some 2 GB thumb drives just like the ones Open Builds sends out formatted fat 32 4096 and it still would not read. Ran the open builds software to make thumb drive supposably compatable with interface still wont read. ?
  7. David the swarfer
    @Mark R the firmware cannot read usb sticks with 4096 byte sectors
    reformat them as 512 byte sectors
  8. Mark R
    Mark R New
    I will give that a try. I thought it would as my micro disks are formatted that way and it reads . Thank you .
