Probe issue
Discussion in 'CAM' started by Robert White, Oct 22, 2023.
  1. Misterg
    Misterg Veteran
  2. Robert White
  3. Misterg
    Misterg Veteran
    To build on what Peter said in the other thread:
    Download the zip file and unzip it somewhere.
    In Control, go to the Macros tab (red arrow) and click the 'Import' button (green arrow). It will ask for a file - point it at the .json file that you downloaded and unzipped.
    That will add a new button to your list of macros (yellow arrow). Click that button to run the probe routine (after positioning the probe at the starting point).
  4. Robert White
    when I click on macro tab like in your picture with red arrow. nothing is there that says import
  5. Robert White
    do I need to be hooked and plugged into the blackbox in order to see it. cause im at home and not at the shop where the machine is.
    Misterg likes this.
  7. Robert White
    thank you. got the software updated now.
  8. Robert White
    thank you so much. it works.
    Misterg likes this.
  9. Robert White
    now I have another issue. along the top it use to have the probe program to run my touch off open build probe. its not there anymore. where can I find it again. or where can I get the macro program for it
  10. Robert White
    now I see you have a macro for finding hole center. can I get that file from you.
  11. Misterg
    Misterg Veteran
  12. Robert White
  13. Misterg
    Misterg Veteran
    No probem here ???
    (Although the 'Add' button has changed to 'Create New' since the original post)
  14. Robert White
    Finally got it to paste. **** Mac computers. Lol
