Openbuilds control software won't open correct file?
Discussion in 'CNC Mills/Routers' started by Baja User, Nov 20, 2023.
  1. Baja User
    Baja User New
    Good morning all! This morning I am having an issue I have never had before and I can't figure out what I'm doing wrong. I am making a cribbage board, designed in Vcarve. All the files work correctly except for the holes. When I try loading the Gcode file for the holes into openbuilds, it loads the cut out file instead. I have deleted, re-created, re-loaded the file many times. I don't understand what is going on. Thanks in advance for any and all insight
    Screenshot 2023-11-20 082918.png Screenshot 2023-11-20 083017.png Screenshot 2023-11-20 083102.png View attachment 59295
  2. Alex Chambers
    I was going to say it was this (see pic) but then I spotted that there doesn't seem to be a toolpath for the profile cut?
    Or is it this - file extension UC instead of NC
    #2 Alex Chambers, Nov 20, 2023
  3. Baja User
    Baja User New
    That was just an attempt at something different to try to get it to work. Original file saved is a pocket toolpath set to 8mm deep, 2.8 dia, using a 1/16 end mill, to multiple files. UC just stands for up cut
    #3 Baja User, Nov 20, 2023
  4. Christian James
    Christian James Journeyman
    It's difficult to see how this could be a problem with OB control. A long shot, but are you saving files in different places i.e. one on a flash drive, another on a laptop perhaps and you're selecting the wrong file source?
