Question about plasma torch and blackbox x4
Discussion in 'General Talk' started by Wendel99, Nov 27, 2023.
  1. Wendel99
    Wendel99 New
    So I purchased a plasma table that was about 90% complete.
    It has a Blackbox 4x, I really love it so far. I've been able to work out all the kinks with moving the axis correctly. I have it working great.
    I'm at the part now where I'm trying to figure out how to wire my Arcfony Cut53n Pro. The cutter has two cnc ports, one 5 pin(for signal control), and one 2 pin(for voltage)
    The directions are a little confusing.
    Code:
    1) Pin 1, The cnc symbol on panel will be light up if Pin1 and Pin 2 short cicuit.
    2) Pin 2 & Pin 3, Signal for Torch Switch(it's also control pilot arc for CNC Torch)
    3,) Pin 4 and Pin 5 Signal for Arc Starting. (Start Plasma cutting)
    I'm confused as to what I would hook up to the blackbox relay port, should it hook up 2&3, or 4&5? I'm assuming that I would hook up 4&5 so it will start cutting, but not sure.
    I don't really want to splice anything into my torch if the cutter has a built in control.
    Any help would be great, and i'll upload a photo of the manual as well.
    Thanks,
    Mark
    4&5 should be the Arc OK signal, not used here (for THC)
    That's the Inverter, telling the CNC's THC, that the Arc has ignited
    2&3 with the badly translated English sounds more like what we want
    Manual makes it more clear
  3. Wendel99
    Wendel99 New
    Thank you Peter!
    So I tried to wire the two red wires to the relay(one to com, one to no). I get a fault on my cutter when I do that.
    I wired the two red to one line and the two black to the other relay port. The torch turns on, and shuts off by command, but it won't restart after.
    I don't like to have my hand held here, but I also don't want to blow up the blackbox(the cutter is from Amazon and I could send it back lol)
    Thoughts?
    Take the hand torch apart, see where the wires go. The button just shorts two wires together. Same thing the relay will do
  5. Wendel99
    Wendel99 New
    Okay, I will just wire it directly to the torch switch. I thought the built in cnc wire would have been a lot easier, but to me it's not!
    Thanks Peter...
  6. Wendel99
    Wendel99 New
    Okay, so, I tried a bunch of different configs and I just had to use wires 2 and 3. It seems to be working fine now!
    Thank you again for you help!
    Cool, see post #2 :)
