X32 and 4th axis
Discussion in 'CNC Mills/Routers' started by Davi Lego, Dec 11, 2023.
  1. Davi Lego
    Davi Lego New
    Good afternoon,
    I'm setting up my x32 for 4th axis. I wired the y1 and y2 in parallel and connected it to y1.
    I wired up the new rotary and placed it on y2. I jogged the y axis to make sure everything moved. All good the y and rotary both moved. Then I flashed the firmware for the 4th axis update. Rebooted the x32 and now have the A axis in Control. Everything looked like it was going smoothly so I knew I was in trouble, low and behold now none of the axis's move. They kinda clunk and move just a hair and that's it. Not sure what the issue is and hoping someone knows what the issue might be.
    You must've accidentally changed to "And erase settings" while flashing, deleting your earlier machine profile. Just load it again, CONTROL > GRBL SETTINGS TAB > SELECT MACHINE FROM THE LIST > SAVE AND RESET WHEN PROMPTED
  3. Davi Lego
    Davi Lego New
    Thanks for your response!
    That fixed it. Sorry about late response but the heat went out and needed tended to.
