X32 stepper voltage
Discussion in 'Controller Boards' started by Hykr3n, Dec 13, 2023.
  1. Hykr3n
    Hykr3n New
    Hello hive mind
    On my x32 all stepper voltage was different on each stepper and i think i was causse my y2 to code. The exclamation mark!
    to ajust them good. Where do i have to take the measurement ?
    Waiting your answer so i don’t fried my board.
    thanks
  2. David the swarfer
    The voltage is constant on the stepper motors.
    The current is adjusted with the adjusters on the side of the X32. Read this docs:blackbox-x32:currentadjustment [OpenBuilds Documentation]
    There is no way to measure the setting, just look at where the screwdriver 'points' relative to minimum and maximum travel.
    The factory sets them all in the middle, that works for most motors on most machines.
  3. Hykr3n
    Hykr3n New
    Im a bit confused, no way to tune the vref?
